[snappyHexMesh] Undefined keyword in dictionary in snappyHexMesh
Like Tree2Likes
  • 1 Post By onyir
  • 1 Post By DanAndrea87
Old   November 20, 2012, 16:25
Default Undefined keyword in dictionary in snappyHexMesh
Rebecca
RebeccaWS is on a distinguished road
Hi
I've been trying to generate a mesh for an internal flow problem. I have successfully generate the background mesh in blockMesh and extracted edges, but when I ran snappyHexMesh from the case directory I got the following error message:
  Create time
  Create mesh for time = 0
  Read mesh in = 0.05 s
  --> FOAM Warning :
      From function entry::getKeyword(keyType&, Istream&)
      in file db/dictionary/entry/entryIO.C at line 77
      Reading /home/RWS/FlowrateCheck/10micronpore/system/snappyHexMeshDict
      found on line 31 the label 10
      expected either } or EOF
  --> FOAM FATAL IO ERROR:
  keyword castellatedMeshControls is undefined in dictionary "/home/RWS/FlowrateCheck/10micronpore/system/snappyHexMeshDict"
  file: /home/RWS/FlowrateCheck/10micronpore/system/snappyHexMeshDict from line 19 to line 34.
      From function dictionary::subDict(const word& keyword)
      in file db/dictionary/dictionary.C at line 479.
  FOAM exiting
I doublechecked my snappyHexMeshDict (please see below) but castellatedMeshControls is definitely defined in the code. Would someone be able to give me a pointer as to what I might be missing/doing wrong?
Many thanks
Reb
** My snappyHexMeshDict file **
|  \\    /   O peration     | Version:  2.0.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;    // For now
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    10micronpore_custom_ascii.stl
        type triSurfaceMesh;
        name flowdomain;
// Settings for the castellatedMesh generation.
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    // maxLocalCells 100000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 3000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 20;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    // maxLoadUnbalance 0.10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 2;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    features
            file "10micronpore_custom_ascii.eMesh";
            level 0;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        "flowdomain_*"
            level (8 9);    // Surface-wise min and max refinement level
    // Resolve sharp angles
    resolveFeatureAngle 180;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (0.002 0.0 0.0);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 10;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 4.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 10;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 10;
    //- Highly experimental and wip: number of feature edge snapping
    //  iterations. Leave out altogether to disable.
    //  Do not use here since mesh resolution too low and baffles present
    nFeatureSnapIter 10;
/*// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        "flowdomain_*"
           nSurfaceLayers 4;
    // Expansion factor for layer mesh
    expansionRatio 1.0;
    //- Wanted thickness of final added cell layer. If multiple layers
    //  is the
    //  thickness of the layer furthest away from the wall.
    //  Relative to undistorted size of cell outside layer.
    //  is the thickness of the layer furthest away from the wall.
    //  See relativeSizes parameter.
    finalLayerThickness 0.5;
    //- Minimum thickness of cell layer. If for any reason layer
    //  cannot be above minThickness do not add layer.
    minThickness 0.1;
    //- If points get not extruded do nGrow layers of connected faces that are
    //  also not grown. This helps convergence of the layer addition process
    //  close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    //- When not to extrude surface. 0 is flat surface, 90 is when two faces
    //  make straight angle.
    featureAngle 90;
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 3.5;
    maxInternalSkewness 2.5;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol -1e-30;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre. This has to be a positive number for tracking
    //  to work. Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.02;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.02;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
RebeccaWS is offline   Reply With Quote
Old   November 26, 2012, 00:14
Default Still having the same problem.
Rebecca
Hi
I still haven't been able to solve the problem. Confusing thing is that the I can't find anything I might have done wrong (syntax mistake, typos etc) in the lines mentioned in the error message (i.e. lines 19-34) in my blockMeshDict file, which are:
castellatedMesh true;  snap            true;
  geometry
          name flowdomain;
Also, the particular bit of code doesn't seem to be directly related to the keyword castellatedMeshControls being undefined. Coud someone please help??
Many thanks in advance
Rebecca
Old   November 26, 2012, 02:09
RDG
onyir is on a distinguished road
Hi Rebecca. I think the problem is having the stl file name starting with a number, instead of a letter.
Regards,
Ricardo.
Saideep likes this.
onyir is offline   Reply With Quote
Old   April 28, 2013, 09:39
reza1980's Avatar
reza
reza1980 is on a distinguished road
I have same problem ,If some body has soloution please let me know
reza1980 is offline   Reply With Quote
Old   May 14, 2013, 15:38
Eric Dalmau
edalmau is on a distinguished road
I didn't try to run SHM without some parameters on the castellated mesh, but you have MaxLocalCells & MaxLoadUnbalance with "//" at the beggining, they aren't recognized so maybe the snappyhexmesh didn't allow to mesh without it.
edalmau is offline   Reply With Quote
Old   October 3, 2013, 21:18
DanAndrea87's Avatar
Andrea Prestigiacomo
DanAndrea87 is on a distinguished road
Hi everybody,
I had the same problem. After same tries I've solved it by adding a box (see the following code) just before "10micronpore_custom_ascii.stl".
It should looks like this:
geometry
    externalBox
        type searchableBox;
        min (-0.3 -0.3 -0.4);
        max (0.3 0.3 0.4);
etc...
So you have to create a box containing your entire geometry. That was the good news.
The bad news is that now I've another error:
keyword scale is undefined in dictionary "/home/REDUCED_TRIGA_core/system/snappyHexMeshDict.geometry.polyMesh.regions"
file: /home/REDUCED_TRIGA_core/system/snappyHexMeshDict.geometry.polyMesh.regions from line 41 to line 77.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 402.
FOAM exiting
Does someone have a solution?
namsivag likes this.
DanAndrea87 is offline   Reply With Quote
Old   August 22, 2016, 17:36
Lucas
LucasCosta is on a distinguished road
Someone have the answer for this problem?
LucasCosta is offline   Reply With Quote
Old   September 6, 2016, 06:19
Agustín Villa
agustinvo is on a distinguished road
Hi Lucas,
as it is said before, the problem seems to appear when your STL filename starts with numbers. I just solved this problem by deleteing those numbers.
agustinvo is offline   Reply With Quote
castellatedmeshcontrols, io error, snappyhexmesh, snappyhexmeshdict
LEMOS InflowGenerator r_gordon OpenFOAM Running, Solving & CFD 103 December 18, 2018 00:58
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 12:38
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
