[snappyHexMesh] Moving/rotating STL/OBJ inside SnappyHexMesh
Like Tree4Likes
  • 4 Post By colinB
Old   May 16, 2013, 03:20
Default Moving/rotating STL/OBJ inside SnappyHexMesh
Pål Grøthe Sandnes
palgroth is on a distinguished road
Hi!
I would like to know if it is possible to transform an imported STL/OBJ geometry within sHM with respect to position and angle?
Best regards Pål
palgroth is offline   Reply With Quote
Old   May 16, 2013, 04:09
colinB is on a distinguished road
Dear På,
since sHM is only a meshing tool this is not possible.
However if you do the transformation in advance of the meshing process
it can easily be done via the command line.
The command you are looking for is called:
surfaceTransformPoints
For the correct usage type
surfaceTransformPoints -help
Also the user guide in section 3 - utilities gives you further hints.
I know for sure that you can manipulate stl files but as far as I remember
it is also capable of treating .obj files.
This command can be used with the correct options for translating, scaling
rotating and many other surface transformations.
I hope I could contribute
regards
colinB is offline   Reply With Quote
Old   May 16, 2013, 04:40
Pål Grøthe Sandnes
This is exactly what I need, thank you very much!! It works perfectly
Old   December 31, 2017, 07:44
ellenripley is on a distinguished road
Sorted me out too Not obvious until it's obvious.
ellenripley is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 05:53
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
Modelling the Heat flow inside the curing oven Marios Vlad CFX 1 February 6, 2008 07:11
