[Commercial meshers] CheckMesh Error when importing from Pointwise |
July 3, 2013, 18:04 |
#21 |
Rick Matus
Rep Power: 17 |
One more suggestion is to run renumberMesh -overwrite after you export the mesh from Pointwise. I'm only an OpenFOAM rookie, but others have reported better convergence when they do this.
July 3, 2013, 19:21 |
#22 |
JP
Rep Power: 13 |
OH WOW!!! Rick,
Thanks a lot for all the help!! I will let you know how it goes!! Thank you so much!! James |
July 4, 2013, 05:16 |
#23 |
JP
Rep Power: 13 |
Hi Rick,
I have tried to open the file you posted on dropbox, but Pointwise gives me an error on the message window. Basically it says "Error: There was an error loading the file: The file is not in the proper format" I am using version Pointwise V16.04 do you know what can be wrong with the file? Thanks, James |
Display Modes | |
Importing 2D separated Hybrid mesh from PointWise to Ansys Fluent | Masoud.A1 | Pointwise & Gridgen | 6 | July 8, 2017 10:23 |
High skewness on importing Pointwise mesh in Fluent | Shubham_SD | Pointwise & Gridgen | 0 | February 7, 2017 10:56 |
Importing multiple P3D grid files into Pointwise | gsh | Pointwise & Gridgen | 6 | January 27, 2017 19:34 |
[Commercial meshers] Pointwise to Foam - cyclic BC points order | Pj. | OpenFOAM Meshing & Mesh Conversion | 5 | August 14, 2016 05:47 |
