[snappyHexMesh] SnappyHexMesh difficulties
Old   July 14, 2015, 02:39
Default SnappyHexMesh difficulties
Ben Chapman
Ben_C is on a distinguished road
I'm new to this so please bear with me if I don't understand the obvious. I have a geometry which is a rectangular block with a barrier inside it. I have constructed the blockMesh for the cuboid by putting the relevant coordinates into the blockMesh dict, now I am trying to use snappyHexMesh to construct the barrier within the cuboid. Am I correct in thinking this is the right way to do things?
Starting from the motorbike example, I have changed the both the blockMesh and SnappyHexMesh dictionary's, I have also generated the .eMesh file for use in the latter and I'm confident this is okay.
Attached is the parasolid file for the geometry, the stl file for the geometry (I can't get solidworks to show the barrier when using the stl file, any ideas?), the blockMesh dict, and the snappyHexMesh dict. These are all in a zip file.
Any help at all is much appreciated. It feels like someone with some snappyHexMesh experience will be able to solve this problem relatively easily.
Thanks,
Ben
Ben_C is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 16:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
