[snappyHexMesh] Can snappyHexMesh give me only Hex. cells?!
Like Tree2Likes
  • 1 Post By hfs
  • 1 Post By SirWombat
Old   September 13, 2012, 14:12
Question Can snappyHexMesh give me only Hex. cells?!
hfs
hfs is on a distinguished road
Hello!
I am trying to mesh the domain around this Umbrella structure [Attached are some screen-shots]
I got a mix of Tet. and Hex. cells
I wonder what parameters in snappyHexMesh control the shape of the cells (Hex. or Tet.)
Can I get a Hex-only-mesh?
Attached is a screen shot of a mesh of generated by snappyHexMesh (a domain around a human head).It consists of only Hex. cells [This screen shot is from the snappyHexMesh tutorial which I found on http://openfoamwiki.net/index.php/SnappyHexMesh]
How did they get this mesh?
Thanks for your Help!
ahparvin likes this.
hfs is offline   Reply With Quote
Old   September 14, 2012, 03:10
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
Hi hfs,
SHM does actually create hex-cells only. They may have other than 6 faces, when deformed by the snapping or add-layers process!
Make sure you have the "Use VTKPolyhedron" option activated in paraview/paraFoam. Then use "extractCellsByRegion"-filter. You will be able to see the actual cells then. See the attachements for screenshots.
G Jan
Bana likes this.
~~~_/)~~~
SirWombat is offline   Reply With Quote
Old   September 14, 2012, 04:55
hfs
Thanks a lot for the quick reply! appreciate it.
Hosam
Old   August 15, 2013, 16:54
Ali
ali.ghaemi is on a distinguished road
Hello guys!
when I run checkMesh over the grid created by snappyHexMesh, it shows that the grid is actually a hybrid one consisting of hexahedra, tetrahedra and sometimes even polyhedra cells. so the question is if there is a way to control the ratio of these different type of cells.
thanks
ali.ghaemi is offline   Reply With Quote
cellZone not taking all the cells inside rahulksoni OpenFOAM 0 January 16, 2019 01:16
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from syntex OpenFOAM Meshing & Mesh Conversion 19 December 10, 2018 07:21
[snappyHexMesh] snappyHexMesh does not remove internal cells Manyway OpenFOAM Meshing & Mesh Conversion 1 December 14, 2016 18:57
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
