[snappyHexMesh] Defective snapping produced deviation
Old   August 12, 2013, 10:00
Default Defective snapping produced deviation
Ilya
skeptik is on a distinguished road
I think the problem has principle character.
I've tried a lot of modifications of some basic sHM dictionaries but if somebody need my source files i will attach it.
The problem:
Questions:
1. Did somebody met similar problem with snapping procedure?
2. What did you do with it to eliminate deviation from stl surface or feature edge?
Thanks.
practice makes perfect
skeptik is offline   Reply With Quote
Old   August 13, 2013, 04:50
Default Done!
Ilya
I've analyzed the problem successfully!
1. To prevent such behavior of sHM the mesh should not have 'empty' patches. So if you need prism layer at the symmetryPlane, you should change patch type only on final stage of your meshing process.
2. So when you have 'empty' patches you will get such messages:
Correcting 2-D mesh motion--> FOAM Warning :
    From function twoDPointCorrector::twoDPointCorrector(const polyMesh& mesh, const vector& n)
    in file twoDPointCorrector/twoDPointCorrector.C at line 152
    the number of vertices in the geometry is odd - this should not be the case for a 2-D case. Please check the geometry.
--> FOAM Warning :
    in file twoDPointCorrector/twoDPointCorrector.C at line 164
    The number of points in the mesh is not equal to twice the number of edges normal to the plane - this may be OK only for wedge geometries.
    Please check the geometry or adjust the orthogonality tolerance.
and then strange message like this one
Correcting 2-D mesh motion ...done
3. I didn't have 2D case (i just wanted to have projected prisms on my symmPlane), so my mesh has a lot of bad elements and sHM gave up my mesh. At the end I had 'waved' mesh as i described at topic.
Old   August 20, 2013, 02:18
Miro
miro2000 is on a distinguished road
oscillation on a surface probably means you overdid it with your smoothing operations.
If your surface is not smooth you should use a better (finer) stl, and not smooth so much. If I understand correctly (i didn't go trough the whole thread) you're meshing an airfoil in 3D? If so, you should check out the dictionary for sHM in incompressible/pimpleDyFoam/wingmotion.
cheers
- miro
miro2000 is offline   Reply With Quote
Old   August 20, 2013, 02:25
Default sHM
Ilya
cheers
- miro
Thanks a lot for your advice and your answer.
But i think it's a vexed question. I mean that in case when one or two patches has 'empty' type sHM trying to 'syncronize' mesh. So points are aligned but in many cases point cloud is not regular, so it's produce additional iterations to find a good alignment. At the end user has waved mesh.
[snappyHexMesh] SHM not snapping to some surfaces Swift OpenFOAM Meshing & Mesh Conversion 13 January 4, 2016 01:56
[snappyHexMesh] Snapping problem, non orthogonal faces Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 April 17, 2015 02:56
temperature dependent deviation hebeldebel STAR-CCM+ 7 July 30, 2014 10:44
[snappyHexMesh] Snapping not enough (even with surfaceFeatureExtract) ironclad OpenFOAM Meshing & Mesh Conversion 1 November 8, 2013 02:58
Standard deviation for every time step shyam OpenFOAM Running, Solving & CFD 3 April 19, 2012 07:39
