[blockMesh] how to create a block inside another block?
Old   August 21, 2013, 12:02
Default how to create a block inside another block?
Hale
Hale is on a distinguished road
hi,
I want to create a rectangular cyllinder inside another rectangular cylinder and define a wall boundary on the faces of the inner cylinder. Is there any easy way to do it in blockMesh? If not please give me some examples to do it in other ways because I looked at som similar cases in snappyHexMesh but I couldn't understand how it works.
I really appreciate your help.
Hale
Hale is offline   Reply With Quote
Old   August 23, 2013, 07:43
colinB is on a distinguished road
Dear Hale,
I have some good news for you:
it is possible in blockMesh! Just use your imagination ;-)
However to give you some detailed help it would be great
to have some more information, like a sketch, or the information
whether you want to have it in 2 or 3D.
But when you draw the problem with some cross-sections
the solution should come up to yourself as well. ;-)
I hope I could push you in the right direction
regards
Colin
edit: I just saw that your problem got solved in the preprocessing
Subforum.
PLEASE keep in mind that cross-posting is a somewhat bad behaviour
and does not necessarily lead to a faster answer rather than disgrace
by other users
colinB is offline   Reply With Quote
Old   August 24, 2013, 07:02
Hale
Hi ColinB,
Thanks a lot for your reply. I have solved the problem with a help from another forum
http://www.cfd-online.com/Forums/ope...tml#post447786
You are absolutely right. It helps a lot when you draw the geometry and use some imagination :-D
how to create a block inside another block? Hale OpenFOAM Pre-Processing 14 January 6, 2016 08:12
Unable to create Block Sparsh Pointwise & Gridgen 1 October 2, 2015 17:09
[blockMesh] Create block structure kmou OpenFOAM Meshing & Mesh Conversion 0 August 23, 2013 10:31
Structured block inside an unstructured block in Gridgen Rebecca Pointwise & Gridgen 5 June 29, 2012 12:17
[DesignModeler] How to create smaller pipe inside bigger pipe? Munggang ANSYS Meshing & Geometry 2 March 7, 2012 14:01
