[Commercial meshers] Periodics using ICEM and OpenFOAM
Old   September 2, 2013, 12:27
Question Periodics using ICEM and OpenFOAM
Agustin
agval79 is on a distinguished road
Dear all,
I have been meshing a simple geometry with ICEM and GAMBIT in order to run some incompressible problems (image attached). I have 2 periodic surfaces. However, dealing with these surfaces has been a nightmare. I have used both programs with different mesh sizes and Boundary conditions with no luck. The closest that I have been is at 8% of difference between surfaces.
Also, I have
* increased the matchTolerance
* increased the writePrecision to 12
* used the command of "Set up Periodicity" in ICEM
But nothing!. Does anyone have any suggestion on how to deal with this issue? I think the converted is not recognising the relation between surfaces, but how can I change that?
Thanks.
agval79 is offline   Reply With Quote
Old   September 4, 2013, 06:11
Markus Rehm
markusrehm is on a distinguished road
Hi Agustin,
I had a similar problem. In my case it was because of the block vertices which were not exactly at the position of the geometry points.
In my case it was a 60° axi symmetric case. I had to put points at the corners of the first cyclic patch and rotate them. Then I forced (snapped) the vertices of the blocks to these rotated points.
The ICEM mesh I exported worked well that way. But I think in terms of tolerance it was also around 0.05.
Which cyclic boundary condition are you using?
Markus
markusrehm is offline   Reply With Quote
Old   September 4, 2013, 13:00
Thumbs up Thanks!.
Agustin
Hi Markus,
Thanks for the advice. I changed the periodic vertices in order to make them easier to spot by the program. Also, remade the geometry to have a coherent periodicity of 40 degrees. Finally, increased the matchTolerance to 0.05, and it's working now!.
Thanks a lot.
[Commercial meshers] Importing ICEM Multiregion Mesh In OpenFOAM Aditya Patil OpenFOAM Meshing & Mesh Conversion 1 May 8, 2017 21:33
[Commercial meshers] converting ICEM mesh to OpenFOAM bmikuz OpenFOAM Meshing & Mesh Conversion 9 May 10, 2016 16:47
[Commercial meshers] ICEM tetra mesh for OpenFoam cfGreen OpenFOAM Meshing & Mesh Conversion 4 October 24, 2013 06:13
[ICEM] Gambit to Openfoam, Gambit to ICEM to Openfoam Rickard.Solsjo ANSYS Meshing & Geometry 7 November 30, 2011 10:20
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
