September 17, 2013, 13:34 |
Velocity "ripples" at AMI
Pete Bachant
Rep Power: 13 |
I'm getting what looks like ripples at the AMI in my 2D mesh after using snappyHexMesh. The meshing dicts are based on those by another forum member Boloar. When I mesh that case, there is no rippling, but when I insert my own geometry (including a smaller cylinder as the AMI surface), I get these ripples. I have meshed with many different refinement levels, iteration numbers, etc., but still the same. Anyone have an idea on what parameter would cause these ripples?
October 18, 2013, 05:56 |
Artur
Rep Power: 19 |
I have seen this in my cases as well. I think it arises due to interpolation errors at the AMI interface. I am not sure, however, if it's a problem with the AMI itself or perhaps the way paraview visualises the data?
October 18, 2013, 13:52 |
Pete Bachant
Rep Power: 13 |
Yeah, I think it's just ParaView's interpolation. If you turn interpolation off and use cell values it looks uniform.
atmBoundaryLayerInletVelocity - Velocity Profile not continuous through domain | sdfij6354 | OpenFOAM Running, Solving & CFD | 3 | July 26, 2017 16:16 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
