October 16, 2013, 08:32 |
open-volume .stl file
Reza
Rep Power: 14 |
I have a .stl file which includes a volume which is open in one side. Now, I want to mesh inside this volume. If I define the point inside volume, it is considered as inside mesh? and I can have mesh inside volume? or the .stl file should be a closed volume? Thanks for any help. |
October 16, 2013, 21:29 |
Dongyue Li
Rep Power: 17 |
Hi Reza,
If you wanna create mesh inside your body, you have to make sure your stl is closed. You can execute: surfaceCheck to see if its closed. If it said its non-closed. You have to modify yout stl. Sometimes its tough to do. Of course there is another way dealing with this. You can generate a blockmesh. Make one of this patch coincide with your stl open patch. |
October 17, 2013, 10:07 |
Solved
Reza
Rep Power: 14 |
Thank you.
As you said the volumes should be closed and otherwise it could not be solved. |
open-volume |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
