[blockMesh] round tube - checkMesh error
Old   November 5, 2013, 11:02
Default round tube - checkMesh error
klemen
fogl is on a distinguished road
When i made a straight tube and "checkMesh" i receive no errors. But when i add a 90° round tube on top, "checkMesh" returns 4 errors (please see below). I made a round tube using this instructions: http://www.cfd-online.com/Forums/ope...blockmesh.html
When i run paraFoam, everything looks nice. I tried to change the tube grading but this didn't solve the "High aspect ratio" problem. I have no idea how could i solved the non-orthogonality error - isn't this obveous that the faces will be non orthogonal if the tube is not straight?
Any idea how can i solve this problem?
Regards
Klemen
Checking geometry...
Overall domain bounding box (-0.008 -0.00654102 0.002) (0.00654102 0.00654102 0.0339986)
Mesh (non-empty, non-wedge) directions (1 1 1)
Mesh (non-empty) directions (1 1 1)
Boundary openness (-1.31732e-17 1.60882e-17 2.02306e-16) OK.
***High aspect ratio cells found, Max aspect ratio: 7.93329e+192, number of cells 330
<<Writing 330 cells with high aspect ratio to set highAspectRatioCells
Minimum face area = 1.05207e-23. Maximum face area = 6.85601e-07. Face area magnitudes OK.
Min volume = 1.66667e-300. Max volume = 1.87778e-10. Total volume = 2.065e-06. Cell volumes OK.
Mesh non-orthogonality Max: 180 average: 17.3038
*Number of severely non-orthogonal faces: 478.
***Number of non-orthogonality errors: 1103.
<<Writing 1581 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 2244 faces are incorrectly oriented.
<<Writing 1189 faces with incorrect orientation to set wrongOrientedFaces
***Max skewness = 8.04445, 7 highly skew faces detected which may impair the quality of the results
<<Writing 7 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 4 mesh checks.
fogl is offline   Reply With Quote
Old   November 13, 2013, 02:46
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
Regards
Klemen
Reduce non-orthogonality, skewness etc.,
Try increasing the number of cells in the round tube.
KANNAN
skyinventorbt is offline   Reply With Quote
Old   July 9, 2014, 06:54
Ali Heidari
Alih is on a distinguished road
hello klemen.
i have the same problem. can you solve this problem??
Thanks.
Regards
Alih is offline   Reply With Quote
Old   July 9, 2014, 15:17
klemen
Hello Ali,
I think i solved the problem by defining the circle (tube cross section) from five patches - a square in the middle and four curved trapezoids around the square.
I don't have the access to my computer at the moment, but i can check it next week - let me know if you don't succeed.
Regards
Klemen
Old   July 10, 2014, 06:27
Ali Heidari
Thank you very much Klemen.
My blockMesh file is:
code:
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.01;
vertices
    (0 8 2)
    (10 0 1.5)
    (10 3 2)
    (1 8 2)
    (0 8 0)
    (10 0 0.5)
    (10 3 1)
    (1 8 0)
blocks
    hex (0 1 2 3 4 5 6 7) (40 15 10) simpleGrading (1 1 1)
edges
boundary
    inlet
        type patch;
        faces
            (0 4 7 3)
    outlet
        type patch;
        faces
            (1 2 6 5)
    Wall
        type wall;
        faces
            (0 1 2 3)
            (4 5 6 7)
            (3 2 6 7)
            (0 1 5 4)
mergePatchPairs
When i run blockMesh with this vertices, i get the error massage:
    Overall domain bounding box (0 0 0) (0.1 0.08 0.02)
    Boundary openness (5.08774e-17 -1.73343e-16 -2.05592e-16) OK.
 ***High aspect ratio cells found, Max aspect ratio: 2.76503e+194, number of cells 6000
  <<Writing 6000 cells with high aspect ratio to set highAspectRatioCells
    Minimum face area = 8.95863e-07. Maximum face area = 6.3631e-06.  Face area magnitudes OK.
    Min volume = 2e-300. Max volume = 2e-300.  Total volume = 1.2e-296.  Cell volumes OK.
    Mesh non-orthogonality Max: 180 average: 157.305
 ***Number of non-orthogonality errors: 16850.
  <<Writing 16850 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 36000 faces are incorrectly oriented.
  <<Writing 19150 faces with incorrect orientation to set wrongOrientedFaces
    Max skewness = 3.57447 OK.
Failed 3 mesh checks.
End
But when i change the vertices(while the geometry remain approximately constant), like this :
vertices
(-5 4 0) //0
(0 -1 0) //1
(0 0.5 0.5) //2
(-4 4 0) //3
(-5 4 2) //4
(0 -1 0.5) //5
(0 0.5 1) //6
(-4 4 2) //7
everything is ok. I'm confused. I don't know how i solve this problem. Do you know how solve this problem?
Thank you very much for your help.
Best regards,
Ali
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
