[snappyHexMesh] checkMesh results question
Old   November 7, 2013, 09:48
Post checkMesh results question
Reza
gooya_kabir is on a distinguished road
Hi FOAMers,
I used snappyHexMesh to generate mesh in my geometry which includes some internal walls and some boundaries. I apply checkMesh to see the result which is as follow:
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
frontAndBack 0 0 ok (empty)
inlet 0 0 ok (empty)
outlet 0 0 ok (empty)
lowerWall 0 0 ok (empty)
upperWall 0 0 ok (empty)
InternalWalls_patch 579220 591327 ok (closed singly connected)
As it shows, number of points and faces for my boundaries is zero, it means that it didn't calculate any surface for them? Also InternalWalls_patch is a internal group which snappy created it for me.
Thank you for any comment and help.
gooya_kabir is offline   Reply With Quote
[OpenFOAM] Visualizing checkMesh results in Paraview Claudio ParaView 15 July 21, 2020 13:58
twoPhaseEulerFoam fluidized bed wrong results FabianB OpenFOAM Running, Solving & CFD 0 June 14, 2017 03:48
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 05:16
Creating a tool to interpolate results Luis Batista OpenFOAM Running, Solving & CFD 2 April 11, 2013 08:15
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 21:36
