[Commercial meshers] Fluent Mesh into OpenFoam
Like Tree2Likes
Old   January 31, 2014, 01:45
sangram
sangram is on a distinguished road
Originally Posted by Kaskade View Post
1. copy the OpenFOAM dam break tutorial to your run directory
2. rename 0 to 0.org
3. rename constant/polyMesh/boundary to constant/polyMesh/boundary.org
4. delete the other files in constant/polyMesh
5. move the .msh-file to the case directory
6. convert it (-scale 0.001 if it's in mm instead of m)
7. run paraFoam and check the mesh
8. run checkMesh -constant
9. if everything checks out, rename 0.org back to 0
10. set your boundary conditions
a. open constant/polyMesh/boundary, to see what boundaries need to be set
b. open each file under 0 and edit it, so that the correct boundary names and conditions are set
Thanks kaskade.....
Actually I am still unable to run the case because of boundary conditions......there are number of faces and points generated after meshing.....and I am unable to locate the sequence of these faces and because of which I am unable to assign boundary conditions.......is it necessary to give start face?....can you please guide on this...
sangram is offline   Reply With Quote
Old   January 31, 2014, 01:56
Onno
Kaskade is on a distinguished road
Apart from the type-entries you don't have to (read: should not) edit the boundary-file manually. The startFace und nFaces entries should be fine after the mesh conversion.
Kaskade is offline   Reply With Quote
Old   January 31, 2014, 02:26
sangram
Thanks Kaskade
When I am running case after editing the files in 0 directory as per boundary ......I am getting following error.....
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/sandeep/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Old   January 31, 2014, 02:39
Onno
That file should exist if you copied the damBreak-Tutorial.
Old   January 31, 2014, 04:14
sangram
kaskade,
Names of boundaries in boundary.org file and boundary file are different......which file should I refer......should I keep both files (boundary and boundary.org) in constant directory before running the case....
Old   January 31, 2014, 04:50
Onno
The boundary.org only serves as reference for you in case you need to lookup which boundary types have been used in the original tutorial. OpenFOAM doesn't use the file due to the .org (short for original).
The boundaries in constant/polyMesh/boundary (without org) are the ones for which the BCs need to be set under 0/.
Old   January 31, 2014, 05:12
sangram
Thanks Kaskade.....
Now it is showing following error after running case using interFoam.....
Create time
fileName::stripInvalid() called for invalid fileName UbuntuOne
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
Old   January 31, 2014, 05:49
Onno
http://www.cfd-online.com/Forums/ope...untuone-d.html
Old   February 3, 2014, 00:16
sangram
Thanks Kaskade.....
Old   February 3, 2014, 04:18
sangram
I wanted to solve acoustic modelling problem in OpenFOAM.......I have difficulty in selection of solver.....guys please help me in selecting correct solver.....
Thanks in advance
Old   February 19, 2014, 06:38
Default fluent mesh to foam
  #31
sangram
Hello All,
I am trying to import one of fluent meshing to openFoam.....but i am getting following error.....please give some suggestion
?Embedded blocks in comment or unknown:
Embedded blocks in comment or unknown:��
�]{�Found end of section in unknown:?
�Embedded blocks in comment or unknown:��
Found end of section in unknown:�
�Dimension of grid: 9
]{?=W�
�Embedded blocks in comment or unknown:f�
wrong token type - expected int, found on line 0 the word '�'
file: IStringStream.sourceFile at line 0.
From function operator>>(Istream&, int&)
in file primitives/ints/int/intIO.C at line 68.
FOAM exiting
Old   February 19, 2014, 09:35
itsme_kit is on a distinguished road
Originally Posted by sangram View Post
Hello All,
]{?=W�
FOAM exiting
Hi
Please follow this way: workbench Mesh: tool - option - meshing- export - ansys fluent - format of input file - ascii
It does work
Just let me know if you still got problem
andbe likes this.
itsme_kit is offline   Reply With Quote
Old   July 1, 2014, 09:26
Anders Berg
andbe is on a distinguished road
Great tip! Thanks a lot!
andbe is offline   Reply With Quote
Old   December 8, 2014, 21:00
Default Patches missing !!
  #34
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hey guys im trying to import a 2D mesh from ICEM to OF
I have tried to import it couple of times no errors but this problem !!!
I have Inlet,top,bottom,curv1,curv2,outlet a total of 6 patches made in icem and I assigned the boundary condition
But when i import it into openFOAM I am getting only 4 patches Curv1, top, outlet and frontandback (automatic patch)
Can you please help me with this problem,
Thanks for your reply,
Hasan K.J
Alhasan is offline   Reply With Quote
Old   December 9, 2014, 00:47
Onno
What commands do you use? Describe your workflow.
Old   December 9, 2014, 06:41
Default Case
  #36
Alhasan's Avatar
Hasan K.J.
I have used fluentMeshToFoam command to import,
I have save it in ANSYS Fluent format,
It is just a simple C-mesh with the C as inlet top as wall bottom as wall and outlet as outflow and the curv1 and curve as wall.
when import it in open foam only 4 patches come I have no idea why tried it many times
Old   December 9, 2014, 07:01
Onno
How does the mesh look in Paraview? OpenFOAM handles 2D calculations in the form of a 3D Mesh with one cell thickness. Maybe that's the problem.
Old   December 9, 2014, 07:41
davide basso
rolloblues is on a distinguished road
fluentMeshToFoam automatically handles 2d meshes by one-cell extrusion along the third direction (infact frontandback patch is created).
my advice is to check in ICEM whether the mesh is correctly associated with the geometry or not.
Maybe "curv2" and "inlet" do not contain mesh elements whatsoever and consequently they are ignored in the conversion process.
rolloblues is offline   Reply With Quote
Old   December 9, 2014, 09:11
Alhasan's Avatar
Hasan K.J.
Actually the mesh looks fine in Paraview and yeah the frontandback was created by itself giving it the thickenss
I have attached the pictures here but the top patch appears in middle of the geometry
I will recheck the association like you said might be an association issue, I will recreate the entire mesh!!
Old   December 9, 2014, 15:35
Alhasan's Avatar
Hasan K.J.
Thanks for you reply, Figured the problem, It was the association !! I have redone it
zhouqy1994 likes this.
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
[Commercial meshers] Fluent case to openfoam mesh Mat_fr OpenFOAM Meshing & Mesh Conversion 8 August 29, 2012 08:10
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
