[Salome] SALOME to OpenFOAM mesh for SRF/MRF computing
Like Tree1Likes
  • 1 Post By linnemann
Old   December 24, 2013, 14:40
Default SALOME to OpenFOAM mesh for SRF/MRF computing
David
davidmd is on a distinguished road
Send a message via ICQ to davidmd
Hello everybody!
I'm trying to import a mesh from salome to openfoam with ideasUnvToFoam utility.
However, I do the rotation and can not install zone for MRF or SRF solver.
I use Openfoam1.7.1
Where can I read about it? Or can someone tell me how to do it at all?
Thank you in advance for your help!
davidmd
davidmd is offline   Reply With Quote
Old   January 9, 2014, 20:51
David
Nobody can help me?
davidmd
Old   January 10, 2014, 02:55
Elvis
elvis will become famous soon enough
Hi David,
from you post it is not clear whether the conversion with ideasUnvToFoam utility does not work properly,
or if you do not know what to do to define the MRF zones?
1. ideasUnvToFoam
2. edit boundary to change patch for MRF zone
3. setSet -batch setBatch
4. setsToZones
elvis is offline   Reply With Quote
Old   January 15, 2014, 09:39
Tobias Adam
Tobias Adam is on a distinguished road
Do you want to rotate the entire mesh, or do you want to have rotational parts and static parts?
If you want to rotate the entire mesh you don´t have to do special zones.
I did one SRF simulation. There my whole mesh rotated, and I just used the same mesh as before without any special zones.
In a few days I´m going to start a new simulation of a windturbine with rotating turbine and static mast. I´d be glad to hear from you if you do something similar!
Best regards Tobias
Tobias Adam is offline   Reply With Quote
Old   February 19, 2014, 22:10
Smile HAWT SRF for OF2.2
Fengjiao Bian
jiaojiao is on a distinguished road
Best regards Tobias
Hi,Tobias! I am recently use the SRF method to model the HAWT but cannot success. I use the OF2.2.2 ,SRFSimpleFoam solver and the mesh is made by Pointwise. I want to make all the mesh rotate with the blade wall static,Could you tell me how to do it ? What set I should do and the steps? Please give me a hand. Thank you so much.
jiaojiao is offline   Reply With Quote
Old   February 20, 2014, 01:28
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Originally Posted by davidmd View Post
Nobody can help me?
Hi
When you have converted the mesh using ideasUnvToFoam you need to run
splitMeshRegions -makeCellZones -overwrite
(OF >= 2.2)
That will create the different regions named region0, region1 etc.
You can then use one of those cellZones inside the dictionaries.
nimasam likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   February 20, 2014, 03:03
David
Originally Posted by elvis View Post
1. ideasUnvToFoam
4. setsToZones
Thank you! It works for me!
davidmd
mesh conversion, mrfzones, openfoam 1.7.1, salome meca
[Salome] how to setFields in openFOAM when you have imported mesh from salome or other package 13msmemusman OpenFOAM Meshing & Mesh Conversion 11 May 18, 2022 07:30
[Salome] Converting Salome wedge mesh to OpenFOAM anon_q OpenFOAM Meshing & Mesh Conversion 4 March 13, 2019 15:13
[Salome] Mesh Salome 7.3.0 to OpenFoam Ahadi OpenFOAM Meshing & Mesh Conversion 5 July 1, 2014 10:11
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Mesh conversion problem from Salome to openfoam jishnusoni OpenFOAM 15 March 3, 2010 01:53
