[snappyHexMesh] Meshing small features
Like Tree1Likes
  • 1 Post By wyldckat
Old   October 2, 2014, 08:52
Default Meshing small features
appie is on a distinguished road
Hi everybody!
When I mesh with snappyHexMesh, some features in my stl are being ignored. The geometry is of order 10 m, but is has some tubes in the centre of 5cm diameter in the centre. At the moment, sHM ignores these small tubes.
How can I make sHM mesh these small features? Can I set a minimum size that sHM should look for?
Many thanks in advance!
Appie
appie is offline   Reply With Quote
Old   October 11, 2014, 12:49
Retired Super Moderator
Bruno Santos
Greetings Appie,
snappyHexMesh is only able to see as much as the base mesh is able to provide.
Therefore, if for example, your base mesh is composed of 1m sided cubes, it's only natural that only the surfaces that are present in 2 or more cubes will be visible. Otherwise, they're just 5cm ants
It's also true that if there are some larger surfaces are seen by snappyHexMesh and have enough refinement assigned to them, then it might be enough refinement nearby those tubes for them to be seen as well.
Best regards,
Bruno
wilsonrcf likes this.
Old   October 16, 2014, 03:20
Dear Bruno,
Many thanks for clarifying how snappyHexMesh deals with this. I was hoping for some workaround, but is doesn't seem to be easy.
In the end, I think that one should try to avoid these scale separation as I am currently having, because it always makes it hard to mesh nicely. Unfortunately the surface of the tube is very important to the case.
Anyhow, thanks again!
Appie
[snappyHexMesh] snappyHexMesh - 3D Wing Meshing Setup & Trials denbjornen OpenFOAM Meshing & Mesh Conversion 1 May 25, 2020 11:14
[ANSYS Meshing] How to avoid Failed Meshing in condition of small interspace between Models? Glorie ANSYS Meshing & Geometry 6 August 1, 2016 14:16
Simulating small features on large models siw CFX 1 February 16, 2012 17:10
Meshing a small section in GAMBIT Anne FLUENT 4 May 12, 2008 12:04
meshing very small tubes Wooster CFX 6 July 23, 2007 10:41
