[Commercial meshers] Problem with cyclic boundaries in Openfoam 2.3, mesh import from ICEM |
April 19, 2014, 10:36 |
Rep Power: 12 |
Dear Foamers,
have a really annoying problem concerning cylic boundaries imported from ICEM. When I use the createPatch command. This is what I get after using createPatch utility: Code:
--> FOAM FATAL ERROR: face 722 area does not match neighbour by 0.010670375885% -- possible face ordering problem. patch:TOP my area:0.000172697081473 neighbour area:0.000172678655029 matching tolerance:0.0001 Mesh face:5008786 fc:(-0.910732468388 -0.121136204077 0.57999998165) Neighbour fc:(-0.91073345224 -0.121136444811 0) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 221. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Do a synchronisation of coupled points after creation of any patches. // Note: this does not work with points that are on multiple coupled patches // with transformations (i.e. cyclics). pointSync false; // Patches to create. patches ( { name cyclic01; patchInfo { type cyclic; neighbourPatch cyclic02; matchTolerance 1e-04; } constructFrom patches; patches (FRONT); } { name cyclic02; patchInfo { type cyclic; neighbourPatch cyclic01; matchTolerance 1e-04; } constructFrom patches; patches (BACK); } ); Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 6 ( CYLINDER { type wall; inGroups 1(wall); nFaces 8556; startFace 4828165; } SIDE { type symmetry; inGroups 1(symmetry); nFaces 16244; startFace 4836721; } FRONT { type patch; nFaces 52661; startFace 4852965; } BACK { type patch; nFaces 52661; startFace 4905626; } INLET { type patch; nFaces 4247; startFace 4958287; } OUTLET { type patch; nFaces 4247; startFace 4962534; } ) // ************************************************************************* // Thank you so much for your help. Best wishes, Scabbard Last edited by Scabbard; April 20, 2014 at 10:12. Reason: Changed [QUOTE] to [CODE][/CODE] |
April 20, 2014, 06:42 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
April 20, 2014, 10:19 |
#3 | |
Rep Power: 12 |
Thank you for your help. I use the structure mesh, and have checked in ICEM. I think both face could be perfectly cyclic. For my case, it is a flow past a cylinder and I want to let the front&back be cyclic. Here is my mesh: https://drive.google.com/file/d/0B1v...it?usp=sharing Could you help me to check where is the error? This problem annoying me for more than a week... Best wishes, Scabbard |
April 20, 2014, 13:47 |
Bruno Santos
Rep Power: 128 |
Hi Scabbard,
The file you shared only has got the mesh. Unfortunately I don't have the time to create a case just to debug your mesh . If you study the file I mentioned in the previous post, you'll see where the "tolerance" settings have to be placed in "createPatchDict". Best regards, Bruno |
April 20, 2014, 15:22 |
#5 | |
Rep Power: 12 |
Sorry to trouble you. I have added the matchTolerance in my createPatchDict and set up 5 values from 1e-04 to 2e-02, but still got the same error... This make me crazy... https://drive.google.com/file/d/0B1v8BP1BA6NQTUJQYW9SU2VpUkE/edit?usp=sharing Here is my whole case. If it is convenient for you, could you help me to check it? Thank you so much for your help. Best wishes, Scabbard |
April 20, 2014, 15:56 |
Bruno Santos
Rep Power: 128 |
Hi Scabbard,
Thanks, that makes it easier! OK, OpenFOAM has been trying to tell you that the patches do not perfectly match. As you can see in the attached image, the patches do not perfectly match up, because even though the face count is identical, their relative locations are not identical. The part on the left is the bottom patch and on the right is the top patch. As I wrote before, if "cyclic" patches don't work, you'll have to rely on "cyclicAMI" patches, which will assign weights to the corresponding faces on the other patch, even if the faces are completely different. Note that the "cyclicAMI" will not try to match up the faces directly, it will look at the location of each face and check what faces are on the other side at the same relative location. Best regards, Bruno
April 21, 2014, 05:02 |
#7 | |
Rep Power: 12 |
Thank you so much for your help. I will have a try to use cyclicAMI. However, do you know what cause the mesh changed in openFoam? Because when I check in ICEM, it seems to be the same both side around cylinder. Best wishes, Scabbard |
April 21, 2014, 16:16 |
#8 | |
Bruno Santos
Rep Power: 128 |
My guess is that since you're not comparing directly one patch on top of the other on ICEM, then the mesh only looks like it's the same. |
April 23, 2014, 07:09 |
#9 | |
Rep Power: 12 |
Dear Bruno, Thank you for you help. Best wishes, Scabbard |
June 11, 2014, 04:49 |
createPatchDict
#10 |
Syed Zahid
Rep Power: 12 |
Dear Bruno
I am also running with the same problem as mentioned by Scaabard, i placed the createPatchDict file in system folder, but the error remains same face 0 area does not match neighbour by 136.618% -- possible face ordering problem. patch:cyclic-6_half0 my area:5.18008e-06 neighbour area:2.75111e-05 matching tolerance:0.0001 Mesh face:6687680 fc-0.494029 0.603639 0.00271732) Neighbour fc-0.494029 0.904544 0.00271732) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 220. |
June 11, 2014, 15:12 |
#11 |
Bruno Santos
Rep Power: 128 |
Greetings Zahid,
I'm not a magician nor a hacker So please don't expect me to just guess the reason why you're getting that error message. So, please provide more information, according to the guidelines given on this thread: http://www.cfd-online.com/Forums/ope...-get-help.html In addition:
Bruno
July 24, 2015, 02:22 |
#12 |
Fabian E.
Rep Power: 16 |
I encountered the same problem and I could solve it by defining rotational periodicity and then by declaring the corresponding vertices in ICEM as periodic. Then Right Click on Faces in the Blocking tree -> Periodic Faces -> ensure that really every periodic face is colored accordingly. createPatch went fine after this procedure. |
January 8, 2016, 17:54 |
#13 |
nasir musa yakubu
Rep Power: 12 |
Hello Bruno,
i have a similar issue, i get the following error message: Code:
parallels@ubuntu:~/OpenFOAM/OpenFOAM-3.0.x/chtMRF$ splitMeshRegions -cellZones -overwrite /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.x-5ead44c48e61 Exec : splitMeshRegions -cellZones -overwrite Date : Jan 08 2016 Time : 21:37:55 Host : "ubuntu" PID : 31837 Case : /home/parallels/OpenFOAM/OpenFOAM-3.0.x/chtMRF nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL ERROR: face 0 area does not match neighbour by 0.0009400302% -- possible face ordering problem. patch:inlet my area:6.589055e-10 neighbour area:6.589117e-10 matching tolerance:1e-06 Mesh face:10399669 fc:(-0.001969071 0.005479679 0.0379999) Neighbour fc:(-0.001968778 0.0590001 -2.032106e-05) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 221. FOAM exiting parallels@ubuntu:~/OpenFOAM/OpenFOAM-3.0.x/chtMRF$ please help, i don't know what exactly to do to fix it, i have tried both ciclic and cyclicAMI patch type, i have also changed my match tolerance i still get the same error. please help. kind regards |
January 9, 2016, 12:09 |
#14 |
Bruno Santos
Rep Power: 128 |
Quick answer: I haven't managed to look into the case, but I suggest that you only convert the patches to "cyclic" or "cyclicAMI" after you've ran splitMeshRegions, not before.
January 28, 2016, 14:19 |
Hi All,
#15 |
Hasan K.J.
Rep Power: 15 |
I have made a 3D mesh in ICEM for an Airfoil and transferd into openfoam, used snappyhexMesh to put the airfoil inside the mesh and did meshing.
I just wanted to change the symmetry patches the front and back of the airfoil into cyclicAMI patches to have a effects of a long airfoil and did it sucessfully, the simulation works my question is what should be my seperationVector (0 0 0); ???in the boundary file, the thickness of my domain is 0.027m, when I have Code:
SYM { type cyclicAMI; inGroups 1(cyclicAMI); transform translational; matchTolerance 0.0001; separationVector (0 0 0.027); nFaces 78084; startFace 6272610; neighbourPatch SYM1; } SYM1 { type cyclicAMI; inGroups 1(cyclicAMI); transform translational; matchTolerance 0.0001; separationVector (0 0 0.027); nFaces 72388; startFace 6350694; neighbourPatch SYM; } when I have SYM (0 0 0.027) and SYM1 (0 0 -0.027) the simulation starts works till 525 and then crashes due to time step continuity error can some one please tell me whats seperationVector ? and what should it it be for such simple airfoil case where the SYM patch actual coordinates are (0 0 0) and SYM1 coordinates in the geometry are (0 0 0.027) or maybe my BC is the reason I have also attached my U and P BC
"Real knowledge is to know the extent of one's ignorance." - Confucius |
January 30, 2016, 14:57 |
separationVector
#16 | |
Hasan K.J.
Rep Power: 15 |
How do you know what is your separationVector Can you please Explain, I have been trying to do Transitional Peridocity for an airfoil in the spanwise direction and failing miserably, futher explained in this post http://www.cfd-online.com/Forums/ope...tml#post582845 Regards, Hasan K.J [ Moderator note: This post and the one below were moved from this other thread: http://www.cfd-online.com/Forums/ope...-parallel.html ]
"Real knowledge is to know the extent of one's ignorance." - Confucius Last edited by wyldckat; March 28, 2016 at 14:18. Reason: see "Moderator note:" |
January 31, 2016, 04:53 |
Cyclic boundary
#17 |
Jean-Michel FONTAINE
Rep Power: 16 |
In your example, the correct setting should be :
cyclic0 { type cyclicAMI; matchTolerance 0.0001; neighbourPatch cyclic1; transform translational; separationVector (0 0 0.027); } cyclic1 { type cyclicAMI; matchTolerance 0.0001; neighbourPatch cyclic0; transform translational; separationVector (0 0 -0.027); } Best wishes J-Michel |
May 27, 2016, 05:54 |
#18 |
Jack
Rep Power: 11 |
I would just like to make use of the excellent advice in this thread to ask if anyone has had the following problem:
creating cyclics works fine using createPatch on my mesh. However, in a different case, I first merge the aforementioned mesh with another (rotor stator meshes) using mergeMeshes, and then run createPatch in an attempt to create cyclics (on the same patches as before) but now I get the face ordering error! What can be wrong? Does merge meshes change the ordering of the faces of my patches? I experimented around and cyclicAMI doesnt produce any error, but I am worried about using cyclicAMI because the mesh periodic patches should be identical (they come from turbogrid). Is there any harm using cyclicAMI? |
September 22, 2016, 04:17 |
sector of cylinder
#19 |
sajad
Rep Power: 11 |
hello guys
is it possible to define "cyclic" or "cyclicAMI" boundary condition for faces "A" and "B" in bellow figure? thanks for your replies. |
September 24, 2016, 14:02 |
#20 |
Bruno Santos
Rep Power: 128 |
Quick answer: depends on whether the mesh has a perfect rotational match or not. In other words, if you rotate the A patch the necessary angle on which the A and B surfaces are overlapping, then the lines around those patches must also match.
[Commercial meshers] A problem to use the mesh made by ICEM in openfoam | 278379rea | OpenFOAM Meshing & Mesh Conversion | 3 | June 6, 2016 02:54 |
Ansys 14.5 Problem Import Mesh from ICEM CFD to CFX | Smiling Assassin | CFX | 1 | May 9, 2014 02:27 |
[Commercial meshers] ICEM tetra mesh for OpenFoam | cfGreen | OpenFOAM Meshing & Mesh Conversion | 4 | October 24, 2013 06:13 |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 10:06 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
