[Salome] DAT file from Salome for use with Foam. |
April 24, 2014, 23:14 |
Andrew Somorjai
Rep Power: 13 |
I used Salome to generate a mesh and sent it to a dat file, mainly because the unv format would lose triangles. Basically I then tried using datToFoam
but I got this error? Code:
--> FOAM FATAL IO ERROR: wrong token type - expected word, found on line 0 the label 1 file: IStringStream.sourceFile at line 0. From function operator>>(Istream&, word&) in file primitives/strings/word/wordIO.C at line 74. FOAM exiting |
May 3, 2017, 04:49 |
Polyhedrons from salome to openfoam
Xabi
Rep Power: 9 |
this post is quite old but did you manage to generate the mesh with the funciton datToFoam? i have made a mesh in salome with the algorythm "body Fitting" which consists of polyhedra apart from hexahedra and if i export the mesh in UNV format the polyhedra are missed. Also if i use the script "salomeToOpenFoam.py" i get an error that says "list assignment index out of range". Does somebody know if it is possible to export polyhedra from salome to openfoam? thank you Xabi |
dat file, mesh, salome |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
