[Salome] DAT file from Salome for use with Foam.
Old   April 24, 2014, 23:14
Default DAT file from Salome for use with Foam.
Andrew Somorjai
massive_turbulence is on a distinguished road
I used Salome to generate a mesh and sent it to a dat file, mainly because the unv format would lose triangles. Basically I then tried using datToFoam
but I got this error?
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 0 the label 1
file: IStringStream.sourceFile at line 0.
    From function operator>>(Istream&, word&)
    in file primitives/strings/word/wordIO.C at line 74.
FOAM exiting
massive_turbulence is offline   Reply With Quote
Old   May 3, 2017, 04:49
Default Polyhedrons from salome to openfoam
xsa
Xabi
xsa is on a distinguished road
this post is quite old but did you manage to generate the mesh with the funciton datToFoam?
i have made a mesh in salome with the algorythm "body Fitting" which consists of polyhedra apart from hexahedra and if i export the mesh in UNV format the polyhedra are missed. Also if i use the script "salomeToOpenFoam.py" i get an error that says "list assignment index out of range".
Does somebody know if it is possible to export polyhedra from salome to openfoam?
thank you
Xabi
xsa is offline   Reply With Quote
dat file, mesh, salome
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
SimpleFoam cannot open include file Marija OpenFOAM Running, Solving & CFD 1 October 28, 2020 10:35
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
