[snappyHexMesh] Problem with extrudeMesh sHM 2D airfoil mesh
Old   September 1, 2014, 03:33
Default Problem with extrudeMesh sHM 2D airfoil mesh
anonymous
ssss is on a distinguished road
Hi foamers,
I'm trying to make a 2D mesh of an airfoil. First I make a square blockMesh as explained in the openfoam guide. And then I run the following commands
foamClearPolyMesh
m4 constant/polyMesh/blockMeshDict.m4 > constant/polyMesh/blockMeshDict
blockMesh
transformPoints -translate "(0 0 -0.5)"
snappyHexMesh -overwrite
flattenMesh
extrudeMesh
All runs okay except that if I run snappyHexMesh, this is the output of extrudeMesh (the bounding box is incorrect). Even changing between back and front in the extrudeDict doesn make difference.
Mesh bounding box : (-10 -10 0) (10 10 1)
And if I don't run snappy before extrudeMesh I get the following output(the bounding box is correct).
Mesh bounding box : (-10 -10 -0.5) (10 10 0.5) //correct
Anyone knows what happens? Thank you
ssss is offline   Reply With Quote
Old   September 1, 2014, 08:55
Elvis
elvis will become famous soon enough
read the "final project" documentation by Alejandro Roger Ull
http://www.cfd-online.com/Forums/ope...gear-pump.html
->The work consists on meshing the geometry with snappyHexMesh in parallel and extruding it with extrudeMesh to make it two-dimensional.
I hope it can be a good guideline for your work.
elvis is offline   Reply With Quote
Old   September 1, 2014, 13:12
anonymous
Originally Posted by elvis View Post
Thank you very much elvis , I think I found how to do it. Thank you
[ICEM] unstructured 2d airfoil mesh Mazur ANSYS Meshing & Geometry 21 June 7, 2023 03:48
Parameters of a good airfoil mesh CharlieBra7o Mesh Generation & Pre-Processing 4 November 20, 2018 14:42
Airfoil simulation solution interfered by mesh Dvergr OpenFOAM Running, Solving & CFD 1 September 28, 2014 02:05
[snappyHexMesh] How to Do External Mesh for Airfoil sHM msuaeronautics OpenFOAM Meshing & Mesh Conversion 1 September 23, 2012 04:00
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 10:55
