[blockMesh] blockMesh error with 6 HEX blocks
Old   September 5, 2014, 03:03
Default blockMesh error with 6 HEX blocks
waku2005 is on a distinguished road
Dear all,
I'd like to run a flow simulation around a very simple obstacle in a duct (2D), like an attached figure.
I wrote blockMeshDict and had a error when I run blockMesh command with the attached simple blockMeshDict (on OF 2.3.x) .
What's wrong in this blockMeshDict?
Thanks in advance
waku2005
error:
--> FOAM FATAL ERROR:
Trying to specify a boundary face 4(17 18 6 5) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 2 named wing.
From function polyMesh::setTopology
const cellShapeList& cellsAsShapes,
const faceListList& boundaryFaces,
const wordList& boundaryPatchNames,
labelList& patchSizes,
labelList& patchStarts,
label& defaultPatchStart,
label& nFaces,
cellList& cells
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 360.
FOAM aborting
waku2005 is offline   Reply With Quote
Old   September 13, 2014, 15:37
jokerito is on a distinguished road
your error code says, that you are defining an internal face, so your Wing is completly in your blockMesh. If you don't want that, you have to adapt your hex blocks or if you don't need initial conditions for the wing, just uncomment your two faces in the wing boundary.
Kind regards,
Mike
jokerito is offline   Reply With Quote
[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face A.A. OpenFOAM Meshing & Mesh Conversion 41 June 26, 2020 07:06
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
[Other] mergeMatchPairs with arcs vainilreb OpenFOAM Meshing & Mesh Conversion 1 August 5, 2013 08:11
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
