[snappyHexMesh] parallel SnappyHexMesh patchField entry
Like Tree1Likes
  • 1 Post By jokerito
Old   September 15, 2014, 10:27
Default parallel SnappyHexMesh patchField entry
insta is on a distinguished road
Hello Everyone
Im trying to solve some k-epsilon case for complex terrain.
everything is working fix with one calculation core. The problem arises when I try to parallelize it.
my sequence of commands is:
blockMesh
decomposePar
mpirun -np X snnapyHexMesh -overwrite -parallel
so far so good.
when I run a solver I get this error:
Cannot find patchField entry for name_name
I think that I understand the problem but dont know how to fix it.
My question is how can I automatically move the BC of the snap from the '0' folder to all the '0' folders located in the different processors folders that were created ?
Any help will be appreciated
insta is offline   Reply With Quote
Old   September 16, 2014, 13:34
jokerito is on a distinguished road
I think you have to reconstruct the Mesh and decompose it afterwards again, because with the new mesh from snappy OF doesn't know the new boundary faces with the boundary conditions. Have a look at this thread:
[#1]
That's my way:
mpirun -np 4 snappyHexMesh -overwrite -parallel
reconstructParMesh -constant -mergeTol 1E-06
decomposePar -force
mpirun -np 2 taskset -c 0,1 interFoam -parallel
ajk likes this.
jokerito is offline   Reply With Quote
Old   September 17, 2014, 00:52
Hi Jokerito
Thanks for the quick reply
I mannaged to fix the problem by adding manually the missing BC, but its a bit annoying
I hope your suggestion with the 'force' command will work at my case.
I've read the thread you suggest, and Bruno speaks there on some magig BC that fix the problem, I will try to figure it out
best regards
Insta
[snappyHexMesh] Running snappyHexMesh in parallel creates new time directories hconel OpenFOAM Meshing & Mesh Conversion 5 September 27, 2022 15:20
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
[snappyHexMesh] SnappyHexMesh in Parallel problem swifty OpenFOAM Meshing & Mesh Conversion 10 November 6, 2015 04:40
Running parallel case after parallel meshing with snappyHexMesh? Adam Persson OpenFOAM Running, Solving & CFD 0 August 31, 2015 22:04
[Other] Cannot find patchField entry for walls eruwaedhiel OpenFOAM Meshing & Mesh Conversion 0 June 8, 2015 22:57
