September 18, 2014, 09:34 |
ideasUnvToFoam in 3D MRF geometry
amine
Rep Power: 12 |
Can anyone tell me how I can resolve this error
I do my mesh under SALOME 6.6.0 (unstructured mesh) and i use OpenFOAM 2.1.1 Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : ideasUnvToFoam cuve_agite.unv Date : Sep 18 2014 Time : 15:23:56 Host : "caelinux" PID : 8801 Case : /home/caelinux/Desktop/tank-MRF nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Processing tag:164 Starting reading units at line 3. l:1 units:" SI: Meter (newton)" unitType:2 Unit factors: Length scale : 1 Force scale : 1 Temperature scale : 1 Temperature offset : 273.15 Processing tag:2420 Skipping tag 2420 on line 9 Skipping section at line 9. Processing tag:2411 Starting reading points at line 20. Read 323638 points. Processing tag:2412 Starting reading cells at line 647299. First occurrence of element type 22 for cell 1 at line 647300 --> FOAM Warning : From function readCells(IFstream&, label&) in file ideasUnvToFoam.C at line 464 Reading "cuve_agite.unv" at line 647300 Cell type 22 not supported --> FOAM FATAL IO ERROR: Attempt to get back from bad stream file: IStringStream.sourceFile at line 0. From function void Istream::getBack(token&) in file db/IOstreams/IOstreams/Istream.C at line 56. FOAM exiting Thanks |
[Salome] ideasUnvToFoam Error: Assertion `nouveau > -1' failed | GerhardHolzinger | OpenFOAM Meshing & Mesh Conversion | 0 | January 29, 2019 10:23 |
[Workbench] Workbench 18.2 SpaceClaim->Mechanical geometry accuracy/tolerance problem | sultzan | ANSYS Meshing & Geometry | 0 | December 13, 2018 17:41 |
Simulation of Radial Fan with simpleFoam MRF | nash | OpenFOAM Running, Solving & CFD | 2 | November 5, 2015 10:12 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
Export geometry file from ansys mechanical | browns6 | Structural Mechanics | 0 | August 27, 2013 16:19 |
