[blockMesh] About blockMesh
Like Tree1Likes
  • 1 Post By wyldckat
Old   September 21, 2014, 13:28
Default About blockMesh
Retired Super Moderator
Bruno Santos
A page dedicated to describing how to use blockMesh exists at openfoamwiki.net: http://openfoamwiki.net/index.php/BlockMesh
Feel free to contribute to that page. I only gave it a stern kick off, but a lot more can be added to that page!
I've stickyfied this thread, to make easier for people to find it.
Here can be discussed how to add content to the wiki page and about this thread; but on this specific "About blockMesh" thread will not be answered questions on how to use blockMesh!
febriyan91 likes this.
Old   October 6, 2019, 05:57
Unhappy How can I STL file for simulation?
Ali İhsan İşgüder
isgudera is on a distinguished road
Hello everyone,
I 'm mechanical engineering student at 4th class. I have a lecture, "Gas Dynamics". And My instructor has given .STL file about nozzle geometry. I have watched most of tutorials but I dont know still haw can I use this geometry. How can I generate blockMesh to this stl file. Plz help me..
isgudera is offline   Reply With Quote
Old   October 6, 2019, 08:35
NablaDyn's Avatar
NablaDyn is on a distinguished road
Originally Posted by isgudera View Post
Hello everyone,
your question is somewhat off-topic. First, you should reconsider what you are trying to do: The fact that you are using STL geometry makes me speculate that you're trying to create a mesh for complex geometry. Hence, blockMesh might not be the best choice in your case (check snappyHexMesh or cfMesh instead). If your geometry is rather regular/simple, then you can give blockMesh or MEGACADS a shot and you probably do not need to employ STL data. In either case, your best shot is to first stick to the respective meshing software manual to get some background knowledge before turning to the forum.
kind regards
NablaDyn is offline   Reply With Quote
Old   May 7, 2021, 03:35
Question checkmesh failure
Shantanu Mandal
SHANTANU MANDAL is on a distinguished road
Hello eveyone,
The checkmesh is showing failed 1 mesh checks:
***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
***Number of edges not aligned with or perpendicular to non-empty directions: 8688
How to resolve this problem?
The blockMeshDict is as :
scale 1;
vertices
(-0.1 0 0) //0
(0 -0.1 0) //1
(0 -0.0025 0) //2
(-0.0025 0 0) //3
(0 0.0025 0) //4
(0 0.1 0) //5
(0.0205 -0.1 0) //6
(0.0205 0 0) //7
(0.0205 0.1 0) //8
(0.1495 -0.1 0) //9
(0.1495 0 0) //10
(0.1495 0.1 0) //11
(-0.1 0 0.0205) //12
(0 -0.1 0.0205) //13
(0 -0.0025 0.0205) //14
(-0.0025 0 0.0205) //15
(0 0.0025 0.0205) //16
(0 0.1 0.0205) //17
(0.0205 -0.1 0.0205) //18
(0.0205 0 0.0205) //19
(0.0205 0.1 0.0205) //20
(0.1495 -0.1 0.0205) //21
(0.1495 0 0.0205) //22
(0.1495 0.1 0.0205) //23
blocks
hex (0 1 2 3 12 13 14 15) (36 24 1) simpleGrading (1 1 1) //0
hex (1 6 7 2 13 18 19 14) (18 24 1) simpleGrading (1 1 1) //1
hex (6 9 10 7 18 21 22 19) (36 24 1) simpleGrading (1 1 1) //2
hex (7 10 11 8 19 22 23 20) (36 24 1) simpleGrading (1 1 1) //3
hex (4 7 8 5 16 19 20 17) (18 24 1) simpleGrading (1 1 1) //4
hex (0 3 4 5 12 15 16 17) (24 36 1) simpleGrading (1 1 1) //5
edges
arc 0 5 (-0.08 0.06 0)
arc 12 17 (-0.08 0.06 0.0205)
arc 1 0 (-0.08 -0.06 0)
arc 13 12 (-0.08 -0.06 0.0205)
arc 3 4 (-0.0015 0.002 0)
arc 15 16(-0.0015 0.002 0.0205)
arc 2 3 (-0.0015 -0.002 0)
arc 14 15(-0.0015 -0.002 0.0205)
boundary
topAndBottom
type patch;
faces
(17 20 8 5)
(20 23 11 8)
(18 13 1 6)
(21 18 6 9)
inlet
type patch;
faces
(0 12 17 5)
(0 1 13 12)
outlet
type patch;
faces
(11 23 22 10)
(10 22 21 9)
frontAndBack
type empty;
faces
(23 20 19 22)
(20 17 16 19)
(17 12 15 16)
(14 15 12 13)
(19 14 13 18)
(22 19 18 21)
(8 11 10 7)
(5 8 7 4)
(0 5 4 3)
(0 3 2 1)
(2 7 6 1)
(7 10 9 6)
mergePatchPairs
Please help me with this. I am doing my project on tandem flapping foil .
Thankyou in advance.
SHANTANU MANDAL is offline   Reply With Quote
Old   May 25, 2021, 14:21
MNM
SHUBHAM9595 is on a distinguished road
This should be related to the warning which comes after executing blockMesh on your provided dict
Found 4 undefined faces in mesh; adding to default patch
You can then use paraFoam -block to visualize these patches along with their vertices numbering.
SHUBHAM9595 is offline   Reply With Quote
Old   September 30, 2022, 23:10
Question The following problem occurs when merging faces
yzj
yzj is on a distinguished road
--> FOAM FATAL ERROR:
Face 220419 reduced to less than 3 points. Topological/cutting error B.
Old face: 2(43281 43282) new face: 2(9260 9239)
From function void Foam::slidingInterface::coupleInterface(Foam:oly TopoChange&) const
in file slidingInterface/coupleSlidingInterface.C at line 1768.
Could you tell me what happened? Thank you very much
Here is my BLOCKMESH file
vertices
//block0 vertices
(-0.088388 0.088388 0) //0
(-0.707106 0.707106 0) //1
(0.707106 0.707106 0) //2
(0.088388 0.088388 0) //3
(-0.088388 0.088388 0.5) //4
(-0.707106 0.707106 0.5) //5
(0.707106 0.707106 0.5) //6
(0.088388 0.088388 0.5) //7
//block1 new vertices
(0.088388 -0.088388 0) //8
(0.707106 -0.707106 0) //9
(0.088388 -0.088388 0.5) //10
(0.707106 -0.707106 0.5) //11
//block3 new vertices
(-0.088388 -0.088388 0) //12
(-0.707106 -0.707106 0) //13
(-0.088388 -0.088388 0.5) //14
(-0.707106 -0.707106 0.5) //15
(-0.088388 0.088388 0.5) //16
(-0.707106 0.707106 0.5) //17
(0.707106 0.707106 0.5) //18
(0.088388 0.088388 0.5) //19
(-0.088388 0.088388 1) // 20
(-0.707106 0.707106 1) // 21
(0.707106 0.707106 1) // 22
(0.088388 0.088388 1) // 23
(0.088388 -0.088388 1) //24
(0.707106 -0.707106 1) //25
(0.088388 -0.088388 0.5) //26
(0.707106 -0.707106 0.5) //27
(-0.088388 -0.088388 1) //28
(-0.707106 -0.707106 1) //29
(-0.088388 -0.088388 0.5) //30 14
(-0.707106 -0.707106 0.5) //31 15
xcells 20;
ycells 20;
zcells 20;
xcells1 20;
ycells1 20;
zcells1 20;
stretch 1;
blocks
//block0
hex (0 3 2 1 4 7 6 5) ($xcells $ycells $zcells)
simpleGrading
// x-direction expansion ratio
1 //no expansion ratio
// y-direction expansion ratio
// z-direction expansion ratio
//1 //no expansion ratio
(0.1 0.2 8) // 20% y-dir, 25% cells, expansion = 4
(0.9 0.8 1) // 60% y-dir, 50% cells, expansion = 1
//block1
hex (2 3 8 9 6 7 10 11) ($xcells $ycells $zcells)
simpleGrading
//block2
hex (8 12 13 9 10 14 15 11) ($xcells $ycells $zcells)
simpleGrading
//block3
hex (0 1 13 12 4 5 15 14) ($xcells $ycells $zcells)
simpleGrading
//block4
hex (0 12 8 3 4 14 10 7) ($xcells1 $ycells1 $zcells1)
simpleGrading
//block5
hex (17 16 19 18 21 20 23 22) ($xcells1 $ycells1 $zcells1) simpleGrading (1 $stretch 1)
//block6
hex (18 19 26 27 22 23 24 25) ($xcells1 $ycells1 $zcells1) simpleGrading (1 $stretch 1)
//block7
hex (30 31 27 26 28 29 25 24) ($xcells1 $ycells1 $zcells1) simpleGrading (1 $stretch 1)
//block8
hex (16 17 31 30 20 21 29 28) ($xcells1 $ycells1 $zcells1) simpleGrading (1 $stretch 1)
edges
//block0 arc
arc 1 2 (0 1 0)
arc 5 6 (0 1 0.5)
arc 0 3 (0 0.125 0)
arc 4 7 (0 0.125 0.5)
//block1 arc
arc 2 9 (1 0 0)
arc 6 11 (1 0 0.5)
arc 3 8 (0.125 0 0)
arc 7 10 (0.125 0 0.5)
//block2 arc
arc 9 13 (0 -1 0)
arc 11 15 (0 -1 0.5)
arc 8 12 (0 -0.125 0)
arc 10 14 (0 -0.125 0.5)
//block3 arc
arc 1 13 (-1 0 0)
arc 5 15 (-1 0 0.5)
arc 12 0 (-0.125 0 0)
arc 14 4 (-0.125 0 0.5)
arc 16 19 (0 0.125 0.5)
arc 17 18 (0 1 0.5)
arc 20 23 (0 0.125 1)
arc 21 22 (0 1 1)
arc 19 26 (0.125 0 0.5)
arc 18 27 (1 0 0.5)
arc 23 24 (0.125 0 1)
arc 22 25 (1 0 1)
arc 26 30 (0 -0.125 0.5)
arc 31 27 (0 -1 0.5)
arc 28 24 (0 -0.125 1)
arc 29 25 (0 -1 1)
arc 16 30 (-0.125 0 0.5)
arc 31 17 (-1 0 0.5)
arc 28 20 (-0.125 0 1)
arc 29 21 (-1 0 1)
boundary
inlet
type patch;
faces
(4 7 10 14)
outlet
type patch;
faces
(20 21 22 23)
(22 23 24 25)
(24 25 29 28)
(28 29 21 20)
pipe
type patch;
faces
(1 5 6 2)
(2 6 11 9)
(9 11 15 13)
(15 13 5 1)
(17 18 22 21)
(18 27 25 22)
(27 25 29 31)
(29 31 17 21)
walls
type wall;
faces
(0 1 2 3)
(2 3 8 9)
(8 9 13 12)
(12 13 1 0)
(0 3 8 12)
column
type wall;
faces
(16 19 23 20)
(23 24 26 19)
(24 26 30 28)
(28 30 16 20)
up1
type empty;
faces
(7 6 5 4)
up2
type empty;
faces
(7 6 11 10)
up3
type empty;
faces
(10 11 15 14)
up4
type empty;
faces
(14 15 5 4)
interface1
type empty;
faces
(16 17 18 19)
interface2
type empty;
faces
(19 18 27 26)
interface3
type empty;
faces
(26 27 31 30)
interface4
type empty;
faces
(30 31 17 16)
mergePatchPairs
(up1 interface1)
(up2 interface2)
(up3 interface3)
(up4 interface4)
yzj is offline   Reply With Quote
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] External flow around cube with blockMesh Woody8 OpenFOAM Meshing & Mesh Conversion 0 March 31, 2015 14:54
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
