[Other] Cylindrical Pipe Mesh Generation
Old   November 6, 2014, 16:03
Default Cylindrical Pipe Mesh Generation
Shivam Sinha is on a distinguished road
I am trying to simulate pulsating flow through a cylindrical pipe. But I am having problems in generating a mesh for the pipe. Can anyone please post a blockMeshDict file for a cylindrical pipe?
Shivam Sinha is offline   Reply With Quote
Old   November 6, 2014, 16:18
otm
otm is on a distinguished road
Hi!
Here is a Python-script that generates a blockMeshDict for a cylindrical pipe:
http://www.cfd-online.com/Forums/ope...tml#post285979
Good luck!
/otm
otm is offline   Reply With Quote
Old   November 7, 2014, 01:50
Hi otm, Thanks for your help.
I had written a blockMechDict file on my own. When I ran blockMech, the following error was generated :
--> FOAM FATAL ERROR:
face 0 in patch 1 does not have neighbour cell face : 4(5 6 9 5)
Can you help me with this?
Here is my blockMeshDict code:
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(0 0.01 0)
(0 0 -0.01)
(0 -0.01 0)
(0 0 0.01)
(4 0 0)
(4 0.01 0)
(4 0 -0.01)
(4 -0.01 0)
(4 0 0.01)
blocks
hex (5 9 6 5 0 4 1 0) (10 10 2000) simpleGrading (1 1 1)
hex (5 6 7 5 0 1 2 0) (10 10 2000) simpleGrading (1 1 1)
hex (5 7 8 5 0 2 3 0) (10 10 2000) simpleGrading (1 1 1)
hex (5 8 9 5 0 3 4 0) (10 10 2000) simpleGrading (1 1 1)
edges
arc 1 4 (0 0.0070710678 0.0070710678)
arc 4 3 (0 -0.0070710678 0.0070710678)
arc 3 2 (0 -0.0070710678 -0.0070710678)
arc 2 1 (0 0.0070710678 -0.0070710678)
arc 6 9 (4 0.0070710678 0.0070710678)
arc 9 8 (4 -0.0070710678 0.0070710678)
arc 8 7 (4 -0.0070710678 -0.0070710678)
arc 7 6 (4 0.0070710678 -0.0070710678)
boundary
inlet
type patch;
faces
(0 4 1 0)
(0 1 2 0)
(0 2 3 0)
(0 3 4 0)
outlet
type patch;
faces
(5 6 9 5)
(5 9 8 5)
(5 8 7 5)
(5 7 6 5)
walls
type wall;
faces
(1 4 9 6)
(4 3 8 9)
(3 2 7 8)
(2 1 6 7)
mergePatchPairs
Old   November 7, 2014, 12:53
otm
I don't think your block topology will give you a good cylinder mesh. You need five blocks like in this example. Also, you are using the same vertex more than once in each block definition. This is not allowed. The same goes for the patches.
I suggest that you read carefully the section about meshes in the OpenFOAM user guide. That particular part of the guide is actually quite comprehensive.
Good luck!
//Olle
Mesh Generation - Prism Layer Stretching Tasneem STAR-CCM+ 3 June 1, 2017 18:41
State of mesh generation Wandadars Main CFD Forum 3 January 5, 2017 12:51
[ANSYS Meshing] Question about mesh generation for a pipe inside a cube lnk ANSYS Meshing & Geometry 0 July 10, 2012 12:28
[ANSYS Meshing] Question about mesh generation learning lnk ANSYS Meshing & Geometry 2 July 7, 2012 06:45
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
