[Other] how to remove or join bad/tiny cells
Old   December 15, 2014, 09:15
Default how to remove or join bad/tiny cells
cutter is on a distinguished road
Hi everybody,
from time to time I have severe problems with meshes that contain bad shaped or very small cells in areas with high fluid velocities or gradients. The cells usually result from the refinement and snapping process of snappyHexMesh or cartesianMesh (cfMesh). Due to these bad cells the simulations either run extremely slow (Courant adaption) or even crash (numeric problems).
Please let me know if you know a tool that allows to join small/bad cells with neighboring cells in order to weaken the CFL conditions or improve the mesh quality!
I already know I can remove some of the bad cells by using checkMesh and setSet (see https://openfoamwiki.net/index.php/SetSet). I also know that it's much better to obtain a better mesh in the first place, but that's not possible for some really complicated geometries.
Thanks!
Cutter
cutter is offline   Reply With Quote
Old   December 18, 2014, 03:11
chriss85 will become famous soon enough
I'm also interested in this. You can use the Co utility to generate a field containing the CFL values, and then filter it with topoSet I think. But I don't know how to go on from there. How to join specific cells with neighbours?
chriss85 is offline   Reply With Quote
[blockMesh] Create internal faces as patch in blockMesh m.delta68 OpenFOAM Meshing & Mesh Conversion 14 July 12, 2018 14:43
[mesh manipulation] how can remove bad cells with assistance of cellSet,setSet,subsetMesh utilities? s.m OpenFOAM Meshing & Mesh Conversion 3 September 23, 2015 12:04
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 09:30
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
