[Other] Trouble using foamFormatConvert
Like Tree8Likes
  • 2 Post By ganem
  • 6 Post By me3840
Old   December 1, 2017, 09:35
Default Trouble using foamFormatConvert
Matheus Ganem
ganem is on a distinguished road
Hello everyone,
I've tried to use foamFormatConvert to convert the polymesh files from binary format to ascii format. But, when I run it, it convert all files (points, boundaries, ...) except the "faces" file. Does anyone have the same problem?
Thanks,
Agnes
ratorres and NotOverUnderated like this.
ganem is offline   Reply With Quote
Old   October 31, 2018, 22:46
me3840 is on a distinguished road
Not sure if you're still working with this, but it appears the problem is in writeMeshObject.H. There's an if statement that filters out the faces file for some reason. I'm not experienced enough to say why (perhaps someone can help with that), but the faces IOobject does not get past:
io.typeHeaderOk<Type>(false) && io.headerClassName() == CheckType::typeName
In order to (hopefully) not break anything, I just went around it with this:
(io.typeHeaderOk<Type>(false) && io.headerClassName() == CheckType::typeName)||(runTime.timeName()=="constant"&&name=="faces")
I tested this on a simple case with a pre-existing solution and it seemed to work without breaking anything. So if anyone can explain what that if statement is doing and why faces aren't included, that'd be super.
me3840 is offline   Reply With Quote
foamformatconvert
[waves2Foam] Having a lot of trouble for a short wavelengths arieljeds OpenFOAM Community Contributions 1 January 2, 2024 13:10
Trouble with rotating wall boundary condition king1989 OpenFOAM Running, Solving & CFD 7 July 29, 2016 13:44
Trouble with sampleDict syntax for OpenFOAM 2.3.1 rawdoggity OpenFOAM Post-Processing 1 February 1, 2015 05:24
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
[GAMBIT] Trouble meshing complex VOF geometry RPJones ANSYS Meshing & Geometry 2 February 14, 2011 18:54
