[blockMesh] blockMesh from scratch - how to visualize it on Paraview?
Old   March 28, 2015, 00:30
Default blockMesh from scratch - how to visualize it on Paraview?
Lisandro Maders
Lisandro Maders is on a distinguished road
The main problem is:
how can I see the mesh I have just created using blockMesh command on paraview, without having all the case files (like fvSchemes, fvSolution, 0 folder files, etc..). The only thing I have is the blockMeshDict file as well as the points, faces, owners, etc. files that were generated with blockMesh. Having only those files, how can I visualize my mesh?
Regards, Lisandro
Lisandro Maders is offline   Reply With Quote
Old   April 9, 2015, 13:35
Default blockMesh from scratch - how to visualize it on Paraview? Reply to Thread
Amod Kumar
amod_kumar is on a distinguished road
One does not need the fvscheme and other filed. The file generated by blockMesh is good enough.
The method I always follow is (I am using Windows version of OF):
1. create an empty file in <casename>.openFOAM, where <casename> without <> is the name of the case such as "Test".
2. Place it in the folder along with the 0/, constant/ and system/ directory.
3. Open the file <casename>.openFOAM in Paraview (select file type "all files" and them type "openFOAM".
You may like to refer to the file
http://www.cfdyna.com/Home/OpenFOAM_Tut.pdf
Regards,
Amod
amod_kumar is offline   Reply With Quote
Old   April 9, 2015, 17:08
Alexander Bartel
alexB is on a distinguished road
@mods: Could be merged with http://www.cfd-online.com/Forums/ope...tml#post539525
@Lisandro:
perhaps I got your Problem.
You have to type "paraFoam" in the case folder after copying just any fvSchemes and fvSolution file from any tutorial you want.
regards
Alex
alexB is offline   Reply With Quote
Old   September 11, 2015, 09:34
Lisandro Maders
I just saw your message now. I have solved the problem and it was exactly this. I didn't have the fvS* files in my case directory...
Thanks anyway!
Lisandro
blockmesh, parafoam, paraview, visualization, visualize grid
visualize a system of particles in tecplot or paraview mnajafi FieldView 0 October 13, 2018 15:02
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release FJSJ OpenFOAM Installation 2 July 23, 2017 05:48
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
[General] paraview ignores SPACING in STRUCTURED_POINTS vtk data? jaffar ParaView 0 November 27, 2012 09:36
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
