[Other] Inserting a swirler tape for flow in a circular cylinder
Old   April 5, 2015, 01:22
Question Inserting a swirler tape for flow in a circular cylinder
Vaibhav
vaibhav.antil is on a distinguished road
Hi
As a part of my project I am simulating jet impingement over a flat plate. The air flows through a pipe with a twisted tape placed asymmetrically, exits and then impingement occurs.
To start, I want to run simulations on air flow in a pipe with a smaller pipe inside and with common axis.
I have used compound in Salome and then generate a unv file to run. It doesnt work . Is there a better solution to this? If you can point me to the right direction, that will be great
Warm Regards
Vaibhav
vaibhav.antil is offline   Reply With Quote
jet impingement, mesh 3d, multiple regions, salome
Flow over a circular cylinder, Re=8000, Problem with cd david caseiro FLUENT 4 October 10, 2017 10:18
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
flow around a circular cylinder with velocity inlet and outflow outlet shuoxue OpenFOAM 1 March 3, 2014 10:42
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
