[Other] Problem with tube meshing
Old   April 13, 2015, 02:09
Question Problem with tube meshing
wangtianjian
wtjhaha is on a distinguished road
Hi all,
I'm going to simulate a quartz tube with heat flux outside the tube to heat the medium in the tube. How can I mesh this problem?
Thank you!
wtjhaha is offline   Reply With Quote
Old   April 22, 2015, 10:37
Alexander Bartel
alexB is on a distinguished road
Hi
I used the search function in this forum "heat flux wall"
result: http://www.cfd-online.com/Forums/ope...ible-case.html seems good
and for the tube a wedge should be sufficient http://www.cfd-online.com/Forums/ope...-possible.html
I don't know which and where to include the material constants for quartz.
regards
Alex
alexB is offline   Reply With Quote
problem in toposet Ahmed Khattab OpenFOAM Pre-Processing 27 March 3, 2023 21:12
Problem with ANSYS Meshing Prasenjit Sanyal ANSYS Meshing & Geometry 1 September 25, 2016 18:44
[ANSYS Meshing] ANSYS Meshing Problem Saikat_FM ANSYS Meshing & Geometry 1 September 15, 2016 02:25
[ICEM] Problem with meshing half NACA0009 in 3D Eizo ANSYS Meshing & Geometry 30 February 17, 2013 02:40
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
