[Other] Solver crashes - bad mesh?
Old   April 14, 2015, 17:45
Post Solver crashes - bad mesh?
Jimmy
MtnRunBeachBum is on a distinguished road
Hi All,
I'm pretty new as a CFD practitioner, especially OF, so bare with me. (My background is in applied aero, as a test engineer.)
I'm creating a test case where I want to run compressible flow around a model, with turbulence. I have the model via .stl files, and I'm able to create a mesh via snappyhexMesh. For now, I'm not too worried about how good the mesh is, I just need to go through the process; obviously a good mesh is a goal, just not mandatory at this stage.
When I try to run the solver, it gets setup to go, loads info from the various dictionaries, then crashes hard. I realize this is the plight of CFD, just looking for some direction on how to proceed. What I think is happening, due to the following in the snappy output, is the mesh cells are not meeting up properly with the model cells:
total attraction master points: 164912 attraction to:
feature point:       0
feature edge:       0
nearest surface:   0
rest:                   164912
I've been trying to setup the surfaceFeatureExtractDict to pull out the eMesh files from my .stl models, but to no avail. One thing I'm not too clear on is how the .eMesh files are created? Do I run the dictionary separately, or does snappy run it?
Any suggestions?
MtnRunBeachBum is offline   Reply With Quote
Old   April 15, 2015, 02:50
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
It would be great, if you could post the complete output of checkMesh
Blog: sourceflux.de/blog
"The OpenFOAM Technology Primer": sourceflux.de/book
Twitter: @sourceflux_de
Interested in courses on OpenFOAM?
jhoepken is offline   Reply With Quote
Old   April 15, 2015, 18:01
Jimmy
I'd rather not, due to the sensitivy of the work. If it's really that critical I can rename the model and post the file for you. Can you give me some suggestions as to what I should be looking for in checkMesh?
A couple things that caught my untrianed eye:
At time = 0:
Mesh OK.
--> FOAM Warning :
    From function polyMesh::readUpdateState polyMesh::readUpdate()
    in file meshes/polyMesh/polyMeshIO.C at line 207
    Number of patches has changed.  This may have unexpected consequences.  Proceed with care
And at time = 1, I get:
Checking geometry...
    Overall domain bounding box (-100 -600 -100) (1200 600 400)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Boundary openness (1.28774e-16 1.06143e-17 -3.51155e-16) OK.
    Max cell openness = 3.61597e-16 OK.
    Max aspect ratio = 11.7652 OK.
    Minimum face area = 0.0335495. Maximum face area = 172.18.  Face area magnitudes OK.
    Min volume = 0.186927. Max volume = 875.888.  Total volume = 7.72916e+08.  Cell volumes OK.
    Mesh non-orthogonality Max: 65.0009 average: 9.96491
    Non-orthogonality check OK.
    Face pyramids OK.
 ***Max skewness = 8.22539, 13 highly skew faces detected which may impair the quality of the results
  <<Writing 13 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
I don't know how much skewness can affect the simulation crashing, but that is something I can look into I suppose...
Thanks for any help!
Old   April 16, 2015, 02:18
Jens Höpken
No problem
Old   April 16, 2015, 11:27
Jimmy
Forgot to throw this up before...output from the solver (sonicFoam) just before it crashes:
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type RASModel
Selecting RAS turbulence model realizableKE
realizableKECoeffs
    Cmu             0.09;
    A0              4;
    C2              1.9;
    sigmak          1;
    sigmaEps        1.2;
    Prt             1;
Creating field kinetic energy K
No finite volume options present
Starting time loop
Time = 0.0125
Courant Number mean: 0.755775 max: 28.4615
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  which: no linux-gate.so.1 in (/home/cfd/OpenFOAM/ThirdParty-2.3.1/platforms/linuxGcc/gperftools-svn/bin:/home/cfd/OpenFOAM/ThirdParty-2.3.1/platforms/linuxGcc/ParaView-4.1.0/bin:/home/cfd/OpenFOAM/cfd-2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/site/2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/platforms/linuxGccDPOpt/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/bin:/home/cfd/OpenFOAM/OpenFOAM-2.3.1/wmake:/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl)
__kernel_sigreturn
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#5  Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#8  Foam::fvMatrix<double>::solve() at ??:?
 at ??:?
#10  __libc_start_main in "/usr/lib/libc.so.6"
#11
 at ??:?
Floating point exception (core dumped)
I'm working to trace back to the origin of the error, but I'm having some difficulty making sense of what OF is telling me. Anyone more experienced with a suggestion as to where to look?
Thanks!
Old   April 17, 2015, 02:57
Jens Höpken
I'm not familiar with sonicFoam, but the maximum Courant number is 28. Try to decrease it.
Old   April 20, 2015, 08:46
Default resolution
Jimmy
See this post for the resolution I came across to my problem:
http://www.cfd-online.com/Forums/ope...tml#post542729
And regarding Courant number, I did modify my original mesh and reduce the timestep to get it more reasonable.
Thanks for the help everyone. Cheers!
code validation, snappyhexmesh, surfacefeatureextract
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
mesh quality problem for displacementSBRStress motion solver zhaozhenkai OpenFOAM 0 January 22, 2017 11:02
[ICEM] Bad Quality **Anny** ANSYS Meshing & Geometry 7 May 28, 2015 05:03
PimpleFoam: Solver Crashes for simple laminar flow mayank.dce2k7 OpenFOAM Running, Solving & CFD 0 May 1, 2014 20:53
Solver Error for fine mesh in translationally periodic element AliLemprex CFX 3 March 26, 2014 14:32
