[mesh manipulation] Second air inlet within the mesh
Like Tree1Likes
  • 1 Post By zfaraday
Old   May 25, 2015, 13:08
Question Second air inlet within the mesh
Flexi1095 is on a distinguished road
I'am searching for a possibility to create a second air inlet within my box (now just a normal rectangle with an inlet on the one side and an outlet on the other side).
In the best case it should be only a very small circle with a second air inlet on a specific position inside the box.
Any idea how I can realize that / is this even possible?
Thank you in advance
Flexi1095
Flexi1095 is offline   Reply With Quote
Old   May 25, 2015, 15:04
Alex
zfaraday will become famous soon enough
Try createPatch utility.
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
zfaraday is offline   Reply With Quote
Old   May 29, 2015, 11:42
Question
Hi zfaraday,
thanks for your reply.
As I am not so experienced with OpenFoam could you (or anyone else) maybe help me a bit more. Which method do I have to use from createPatch to change a certain cell to an inlet?
(-overwrite, -parallel, -roots "(DIR1 [...DIRN])", -region NAME, -case DIR, -noFunctionObjects)?
Flexi1095
Old   May 29, 2015, 12:07
Alex
Well, first of all, whenever you need some information about the usage of a utility try the following command:
 grep -ri "utility name" $FOAM_TUTORIALS
With this you will find all the files where the utility is called in the tutorials directory. Otherwise, you may also try this other command
 find $FOAM_TUTORIALS -name "utility name*"
With this one you will be able to find all the files with the name of the utility ended with "Dict" (it is important to use * after the utility name! Otherwise you won't find anything), since many of the utilities use entries coming from dictionaries with its own name ended with "Dict". It is important to study these files in order to be able to run many of the utilities!
Besides that, I wil give you some information about the use of createPatch utility, since today I have use it for the first time! I would need more information about your geometry in order to give you more accurate help. However, as a quick guide, I will tell you that first you need to create a faceSet with the patch faces you want to convert into your new inlet patch. I recomend you to do it by making use of topoSet utility. Once you have created your faceSet with the faces that you want to be in a new patch you can run createPatch, after having set up correctly the createPatchDict, of course...
Hope it helps! Regards,
Alex
Flexi1095 likes this.
Old   June 4, 2015, 17:31
Hi zfaraday,
thank you so much for your help so far!
With the commands I found some informations, but when I want to create a cellSet it returns an error.
My topoSetDict looks like this:
|  \\    /   O peration     | Version:  2.3.0                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
     name    Einlass;
     type    cellSet;
     action  new;
     source  cellToFace;
  source nearestToCell;
       points ((0.992718405535614, 0.00241252922952359, 0.0319775971417239) );
An the eror:
michael@michael-Lenovo-G510:~/OpenFOAM/michael-2.3.0/run/AutoWF2014$ topoSet
Build  : 2.3.0-f5222ca19ce6
Exec   : topoSet
Date   : Jun 04 2015
Time   : 23:16:12
Host   : "michael-Lenovo-G510"
PID    : 5154
Case   : /home/michael/OpenFOAM/michael-2.3.0/run/AutoWF2014
nProcs : 1
Create time
Create polyMesh for time = 0
Reading topoSetDict
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'actions' on line 16 and ending at line 34"
file: /home/michael/OpenFOAM/michael-2.3.0/run/AutoWF2014/system/topoSetDict at line 34.
    From function primitiveEntry::readEntry(const dictionary&, Istream&)
    in file lnInclude/IOerror.C at line 132.
FOAM exiting
Any idea? Is my topoSet wrong?
If you are interested in the geometry have a look at the attachment. It's like a small F1 car I want to create the second outlet (1 cell would be enough) at the left end of car in the mid of the cylinder.
Best regards,
Flexi1095
Old   June 5, 2015, 07:07
Alex
You missed a semicolon behind the last bracket!
Old   June 9, 2015, 16:45
Post
Thank you zfaraday! Searched over 1 hour and in the end only one semicolon was missing. >.<
Now I have created the cellSet and with that the faceSet.
If I understood correctly I can now run createPatch?
My createPatchDict looks like:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
pointSync false;
patches
        // Name of new patch
        name Einlassluft;
        // Type of new patch
        patchInfo
	type patch;
        // How to construct: either from 'patches' or 'set'
        constructFrom set;
	// If constructFrom = set : name of faceSet
        set Einlassface;
But it returns:
michael@michael-Lenovo-G510:~/OpenFOAM/michael-2.3.0/run/AutoWF2014$ createPatch
Exec   : createPatch
Date   : Jun 09 2015
Time   : 22:25:44
PID    : 3949
nProcs : 1
Create time
Reading createPatchDict
Adding new patch Einlassluft as patch 7 from
    type            patch;
Read 119 faces from faceSet Einlassface
--> FOAM FATAL ERROR:
Face 68824 specified in set Einlassface is not an external face of the mesh.
This application can only repatch existing boundary faces.
    From function createPatch
    in file createPatch.C at line 727.
FOAM exiting
If I interpret it right a new patch can only created when the faces are not already part of the mesh.
So do I first have to delete the relevant faces (with setSet??) and then run createPatch or is there another way?
Best regards and thank you so much for the help so far.
Flexi1095
Old   June 10, 2015, 07:09
Alex
Ok, this problem has an easy diagnostic. The faceSet you created contains internal faces instead of only contain external faces, which is a requirement when you use createPatch since it can only convert external faces into patch faces but it cannot handle internal faces.
Rebuild your faceSet in order to make it only contain external faces.
Old   June 10, 2015, 14:13
Question
Hi zfaraday,
can you maybe give me a hint how to create the faceSet with only external faces? Do I have to use another utility?
I've tried to add the invert command within topoSet, but it occurs the same error.
- Flexi1095
Old   June 10, 2015, 15:21
Alex
Well, I always do it with topoSet. My advice is to select the whole existing wall patch where you want to add the new inlet patch and convert it into a faceSet. Once you have the existing patch in a faceSet, delete the surplus faces until you get only the needed faces in the faceSet. Then you can use it so as to create the the patch properly!
Hope it helps,
Alex
massflow inlet on cooling plate definition inside the ambient air box farianka FLUENT 0 March 21, 2017 06:27
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
