[Other] blockMeshDict missing for airfoil2D tutorial
Old   December 9, 2015, 18:45
Default blockMeshDict missing for airfoil2D tutorial
thunde47
thunde47 is on a distinguished road
I am new to OpenFOAM. After going through cavity and dam break tutorials, I finally moved on to airfoil2d tutorial. First thing I checked for familiar files like blockMeshDict, etc. Its missing!
After doing some reading on internet and this forum, it seems that the mesh file for this case is not created in the usual way. But, where is the simulation getting its mesh? How can I check the file used for creating the mesh for this simulation? I checked the Allrun file. It has no indication of where the mesh is coming from.
Eventually, how do I run this simulation?
thunde47 is online now   Reply With Quote
Old   December 10, 2015, 02:00
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
http://www.cfd-online.com/Forums/ope...airfoil2d.html
It is the first link on results page of the https://www.google.fr/search?q=openfoam+airfoil2d+mesh.
And you can generate airfoil meshes with different external software, construct2d for example. Do not know what was used for the case.
alexeym is offline   Reply With Quote
Old   December 10, 2015, 02:10
thunde47
I have already gone through that link. I understand that the mesh is already created, but then the question is still unanswered - where is the mesh file? It has to be somewhere.
I do not know what was used for the case. This is what I got with the OpenFOAM installation itself.
Old   January 10, 2016, 02:36
Antimony is on a distinguished road
I have no idea what was used to create the mesh either.
But to answer your question, the mesh for the case is present (as usual in OF) in constant/polyMesh. The files - faces, points, neighbours, owners and cells - pretty much convey all the information to OpenFOAM about the mesh.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   January 12, 2016, 03:17
In case anyone is interested, here is my version of a working blockMeshDict for an airfoil case. It is based on the NACA0012 airfoil, with the trailing edge extrapolated to a single point and the subsequent chord length rescaled to unit length
The interpolation points for the splines are the points listed for NACA0012 in the UIUC database.
Cheers,
Antimony
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial mörli OpenFOAM Running, Solving & CFD 0 April 9, 2019 11:50
[blockMesh] Creating an axisymmetric piston cylinder in blockMeshDict foadsf OpenFOAM Meshing & Mesh Conversion 9 August 23, 2018 07:54
CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM tom96 FLUENT 1 May 21, 2018 00:24
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
