[Other] Function determined refinement region |
July 16, 2015, 02:49 |
hekseli
Hey!
I would like to manage to make cell split refinement for a region, which, e.g. outer surface is determined as a function. This surface could be for example a parabolic cylinder x^2 + y +z =0 or something else. Naturally I could always create this kind of surface in .stl or similar format and then use refineMesh+topoSet functionality but I don't find this feasible when playing around and changing similar mesh slightly from case to case. I would assume that by abusing topoSet feature and some scripting this could be possible. Any ideas or experience? Cheers |
July 23, 2015, 02:17 |
hekseli
In the end I decided to create parametrized scripts for stl files via openscad and then just refine by using them. Anyway if I have more time in some point I check if this could be possible via existing functions in OF.
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 06:51 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
