[snappyHexMesh] Patch volume refinement in sHMD
Like Tree2Likes
  • 2 Post By wyldckat
Old   August 11, 2015, 10:58
Default Patch volume refinement in sHMD
shashank moghe
smog is on a distinguished road
Hello all,
I want to region-refine a patch (imported from a .stl file and included in the "regions" section of the Geometry subdict in sHMD [with the same name as the .stl patch]). Has anyone tried it yet?
As it goes, the geometry of my .stl file is such that I cannot use a refinementBox/refinementSphere/etc. for this volume refinement. It would be simpler for me to just refine the region bounded by this patch. Any ideas as to what the syntax should be? This documentation link says it is possible (at the bottom of the page).
http://www.openfoam.org/version2.2.0/snappyHexMesh.php
"users can now specify surface names for region refinement using wildcards; "
Any help will be highly appreciated.
P.S: I tried these permutations before and failed to refine the region:
1) stlFileName.stl_patchname
2) "patchame"
3) "patchname_*"
smog is offline   Reply With Quote
Old   August 13, 2015, 18:33
seanmike31 is on a distinguished road
HI, I found this tutorial on youtube. Try it.
https://www.youtube.com/watch?v=ObsFQUiVi1U
seanmike31 is offline   Reply With Quote
Old   August 13, 2015, 19:46
shashank moghe
I have seen this tutorial. Unless I missed the part where he talks about this problem.
Old   August 14, 2015, 00:36
DanielP
danielpiaget is on a distinguished road
Hello Smog,
In snappyHexMesh, one can define patch(es) or surfaces geometry in the following ways.
The first method is when the blockMesh mesh is defined. I recommend that you id all 6 surfaces with patches names.In other words, inside the blockMeshdict defines each patch with the 4 summit points (in counter-clockwise fashion).
The second method is inside the stl file. Each patch can be separated likes this:
solid outlet
facet normal +0.0000000E+00 +0.0000000E+00 +1.0000000E+00
outer loop
vertex -2.0000000E-01 +1.5000000E-01 +2.0000000E+00 vertex -2.0000000E-01 -1.5000000E-01 +2.0000000E+00 vertex +2.0000000E-01 -1.5000000E-01 +2.0000000E+00
endloop
endfacet
endsolid
Once all that works fine, you can define inside the Geometry section
a region as follows:
regions
outlet
name my_outlet;
See also the links below:
https://sites.google.com/site/snappy...t#TOC-geometry
https://openfoamwiki.net/images/f/f0...SlidesOFW7.pdf
Daniel
danielpiaget is offline   Reply With Quote
Old   August 14, 2015, 14:04
shashank moghe
That is not an answer to my question. I can very well define a patch in the sHMD, my question was whether I can refine the volume bounded by a patch.
Old   August 14, 2015, 15:52
Retired Super Moderator
Bruno Santos
Greetings to all!
I was wondering about this today as well and diagnosed it with a modified case of the tutorial "heatTransfer/buoyantBoussinesqSimpleFoam/iglooWithFridges". I added a new STL file to the case named "sliced0.stl" and then added the following to "system/snappyHexMeshDict":
  • Inside the "geometry" block:
        sliced0.stl
            type triSurfaceMesh;
            regions
                ascii
                    name myPlane;
  • Inside the "castellatedMeshControls.refinementRegions" block:
            sliced0.stl
               mode distance;
               levels ((0.3 4) (0.6 3));
    Note: The name "myPlane" cannot be used inside this block.
In case you assigned a new name for the STL, for example:
    sliced0.stl
        name mySlice;
Then it's the name "mySlice" that has to be used in "castellatedMeshControls.refinementRegions".
Therefore, you cannot use the name for one of the solids inside the STL and you should be careful with whether you renamed the main STL geometry.
This is the feature that smog pointed out from the release notes for OpenFOAM 2.2.0 .
Best regards,
Bruno
Bollonga and smog like this.
Old   September 1, 2015, 10:51
shashank moghe
Thank you Bruno for the reply. Exactly what I needed, although I worked around the problem in the same way as you did- adding another .stl file and refining that region. Works perfectly fine.
mesh refinement, refinementregion
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
