[snappyHexMesh] variables in snappyHexMeshDict |
August 28, 2015, 11:00 |
shashank moghe
Rep Power: 11 |
Hello all,
I am creating the mesh and having some trouble getting the layers added to a wall patch (base cell size = 2 mm, level of refinement = 4). The funny thing is, the layers were added correctly on a refinement level of 3, but not when the refinement level = 4. I am wondering what the problem is. If you can let me know the significance of a few variables in the sHMD, that would be great. Here is the snippet of the concerned section of sHMD: addLayersControls { relativeSizes true; //false means thickness values are absolute.True means values are relative to surface mesh dimension. //list patch names inside "layers" to add cell layers to those patches layers { wall_imported { nSurfaceLayers 3; } } expansionRatio 1; finalLayerThickness 0.33; minThickness 0.05; nGrow 0; //WHAT DOES THIS VARIABLE DO?? // Advanced settings featureAngle 180; //WHAT DOES THIS VARIABLE DO?? nRelaxIter 20; nSmoothSurfaceNormals 1; nSmoothNormals 3; nSmoothThickness 10; maxFaceThicknessRatio 0.5; //WHAT DOES THIS VARIABLE DO?? maxThicknessToMedialRatio 0.3; //WHAT DOES THIS VARIABLE DO?? minMedianAxisAngle 80; //WHAT DOES THIS VARIABLE DO?? nBufferCellsNoExtrude 0; nLayerIter 50; } |
August 29, 2015, 08:22 |
#2 | |
Some help:
http://noc.ac.uk/f/content/science-t..._2_meshing.pdf anyway, if you look to default dictionary you can find more variables. By now I haven't clearly undestarnd what all they do; the only way to figure it out is to read the code, but for that, you have to master C++. Bye |
August 31, 2015, 09:33 |
shashank moghe
Rep Power: 11 |
I have read the presentation. It is amazing indeed, although, when I actually try out the code, something bizarre keeps happening (like what I mentioned in my initial post).
September 1, 2015, 07:31 |
layer addition is one of the most painful task in snappy Hex Mesh; I think you already firgured it out by googling "layer addition".
Anyway; here's a link to a pdf about a conversation I had on the OpenFOAM group in Linkedin. https://www.dropbox.com/s/u4ct0lau94...kedin.pdf?dl=0 Maybe it could help. One more hint is to check the quality of the stl surfaces. http://www.cfd-online.com/Forums/ope...pyhexmesh.html By posting a picture of your geometry and mesh, you could get more help from the rest of the cfd-online community. Regards |
September 1, 2015, 09:32 |
shashank moghe
Rep Power: 11 |
Thank you so much, but my office connection in blocking the dropbox link. Can you provide the link to the Linked-In conversation or PM me the PDF please? Thank you again.
September 1, 2015, 12:20 |
https://www.linkedin.com/grp/post/19...s-post-b-title
you're welcome. here it follows a template of mine I generally use to prepare the mesh. As posted before, I'm not mastering all variables. Code:
FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh false; // make basic mesh ? snap false; // decide to snap back to surface ? addLayers true; // decide to add viscous layers ? geometry // Load in STL files here { amiRot1.stl {type triSurfaceMesh; name amiRot1;} amiRot2.stl {type triSurfaceMesh; name amiRot2;} amiRot3.stl {type triSurfaceMesh; name amiRot3;} wallStat.stl {type triSurfaceMesh; name wallStat;} blade.stl {type triSurfaceMesh; name blade;} bladeInf.stl {type triSurfaceMesh; name bladeInf;} bladeTop.stl {type triSurfaceMesh; name bladeTop;} boccInf.stl {type triSurfaceMesh; name boccInf;} boccSup.stl {type triSurfaceMesh; name boccSup;} fanHub.stl {type triSurfaceMesh; name fanHub;} }; castellatedMeshControls { maxLocalCells 2000000; //max cells per CPU core maxGlobalCells 4000000; //max cells to use before mesh deletion step minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages maxLoadUnbalance 0.05; //0.1 default nCellsBetweenLevels 1; // expansion factor between each high & low refinement zone // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command ( {file "amiRot1.eMesh"; level 1;} {file "amiRot2.eMesh"; level 1;} {file "amiRot3.eMesh"; level 1;} {file "wallStat.eMesh"; level 1;} {file "blade.eMesh"; level 2;} {file "bladeInf.eMesh"; level 2;} {file "bladeTop.eMesh"; level 2;} {file "boccInf.eMesh"; level 2;} {file "boccSup.eMesh"; level 2;} {file "fanHub.eMesh"; level 1;} ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces // Surface-wise min and max refinement level { amiRot1 {level (2 2);} amiRot2 {level (2 2);} amiRot3 {level (2 2);} wallStat {level (1 2);} //(2 2 ) blade {level (2 2 );} bladeInf {level (3 3);} bladeTop {level (2 2);} boccInf {level (1 1 );} boccSup {level (3 3);} fanHub {level (2 2);} } resolveFeatureAngle 80; //was80 Resolve sharp angles // Default 30 refinementRegions // In descending levels of fine-ness { //refine1 {mode inside; levels ((3 4));} } locationInMesh (0 0 0.167); //to decide which side of mesh to keep ** allowFreeStandingZoneFaces false; //true; } // Settings for the snapping. snapControls { nSmoothPatch 0;// era 3; tolerance 2.0; //era 3.0 default is 2 nSolveIter 250; //era30 nRelaxIter 5; // efault 5 nFeatureSnapIter 30; // default is 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces } // Settings for the layer addition. addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName { relativeSizes false; // was true con false hanno la stessa grandezza layers { blade {nSurfaceLayers 1;expansionRatio 1.12;firstLayerThickness 0.002;minThickness 0.00005;} bladeTop {nSurfaceLayers 1;expansionRatio 1.12;firstLayerThickness 0.001;minThickness 0.00005;} bladeInf {nSurfaceLayers 1;expansionRatio 1.12;firstLayerThickness 0.001;minThickness 0.00005;} fanHub {nSurfaceLayers 1;expansionRatio 1.12;firstLayerThickness 0.0022;minThickness 0.0001;} boccInf {nSurfaceLayers 1;expansionRatio 1.12;firstLayerThickness 0.002;minThickness 0.00005;} } expansionRatio 1.12; //thickness 0.002; firstLayerThickness 0.002; //was 0.00018 minThickness 0.00001; nGrow 0; // was 1 // Advanced settings // Static analysis of starting mesh featureAngle 310; //- When not to extrude surface. 0 is flat, 90 is right angle. nRelaxIter 5; //era 13 //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. maxFaceThicknessRatio 0.8; // Stop layer growth on highly warped cells // Patch displacement nSmoothSurfaceNormals 150; //100 Number of smoothing iterations of surface normals nSmoothThickness 50; //100 Smooth layer thickness over surface patches // Medial axis analysis minMedianAxisAngle 135; //135 Angle used to pick up medial axis points maxThicknessToMedialRatio 0.9; // Reduce layer growth where ratio thickness to medial distance is large nSmoothNormals 50; // Number of smoothing iterations of interior mesh movement direction // Optional: //nMedialAxisIter 10; //limit the number of steps walking away from the surface. Default is unlimited. //nSmoothDisplacement 90; //smooth displacement after medial axis determination. default is 0. // (wip)Optional: //detectExtrusionIsland true; // do not extrude a point if none of the surrounding points is not extruded. Default is false. // Mesh shrinking slipFeatureAngle 30; //at non-patched sides allow mesh to slip if extrusion direction makes angle larger than slipFeatureAngle. Default //is 0.5*featureAngle. nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations nLayerIter 50; //Overall max number of layer addition iterations. The mesher will exit if it reaches this number of iterations; //possiblywith an illegal mesh. nRelaxedIter 0; // Max number of iterations after which relaxed meshQuality controls get used. Up to nRelaxedIter it uses the settings // in meshQualityControls, after nRelaxedIter it uses the values in meshQualityControls::relaxed. //IMPOSTANDOLO A 0 SHM UTILIZZA IMMEDIATAMENTE I VALORI RELAXED // Additional reporting: if there are just a few faces where there // are mesh errors (after adding the layers) print their face centres. // This helps in tracking down problematic mesh areas. //additionalReporting true; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { /* disabling mesh quality MaxNonOrtho 180; maxBoundarySkewness -1; maxInternalSkewness -1; maxConcave 180; minVol -1e33; minTetQuality -1e30; minTwist -1e30; minDeterminant -1; minFaceWeight -1; minVolRatio -1; minArea -1; minTriangleTwist -1; */ maxNonOrtho 55; //default 65 maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 60; //default 80; minVol 1e-13; minTetQuality -1e30; minFlatness 0.5; minTetQuality 1e-9; minArea -1; minTwist 0.05; minDeterminant 0.001; minVolRatio 0.01; minFaceWeight 0.05; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; // Advanced relaxed // mesh Quality Controls for layer addiction phase { maxNonOrtho 69; //maxBoundarySkewness 25; //maxInternalSkewness 5; maxConcave 100; minTwist 0.02; minFaceWeight 0.02; minDeterminant 0.0001; } } // Advanced debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; // ************************************************************************* // |
September 1, 2015, 16:45 |
shashank moghe
Rep Power: 11 |
student666, thank you for posting the sHMD. It is extremely helpful looking at the settings of another user. I am now playing around with my sHMD values as well.
September 24, 2015, 17:34 |
Layers in Complex geometry
Werner
Rep Power: 10 |
Hi !
I'm having problems as well with the Add Layers function in snappyHexMesh. I'm trying to put just 1 layer around a complex geometry in 3d and as the addlayers application iterates the layers that I had at the beginning get all removed, aparently because they didn't comply with the meshquality controls.. I tried changing several parameters imitating M.C.'s setting but I got no improvement. Is this a problem of my geometry or could I change a parameter to improve the layer addition? I'm ataching a pic of my layers around a slice of my geometry and both sHMD and log.sHM. thanks in advance, Werner |
[swak4Foam] How to define boundary condition variables by using previosly defined variables? | pawlo | OpenFOAM Community Contributions | 8 | September 13, 2020 11:37 |
Some variables not loading in Tecplot | nick.l.thomas | Tecplot | 1 | October 25, 2018 17:48 |
[General] IntergateVariables filter. How to select variables to integrate? | Antech | ParaView | 0 | June 4, 2015 02:38 |
Problem Accessing Obscure Data Variables in Fluent | randomPhil | Fluent UDF and Scheme Programming | 3 | December 12, 2013 11:42 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
