[Other] Confused about the block definition
Old   September 30, 2015, 09:45
Default Confused about the block definition
ziming zhu is on a distinguished road
Hello guys,
I am working on a simulation about the flow around a cylinder,and I have problems when writing the blockMeshDict .The tuition has divide the region as the follwing picture:2015-09-30 21:29:10????.jpg
Then he writes hex (5 4 9 10 24 23 28 29) (80 20 1) simpleGrading (10 1 1) and hex (16 10 9 15 35 29 28 34) (20 80 1) simpleGrading (1 10 1) in the blocks definition.
Why don't the two blocks have the same value,the number of cells in each direction should be the same.
Any suggestion helpful.
Regards,
Ziming Zhu
ziming zhu is offline   Reply With Quote
Old   November 23, 2015, 07:27
cutter is on a distinguished road
Hi!
That's right - the cell numbers need to match for neighboring block edges and faces.
The definition of blocks needs to follow a certain scheme, have a look at figure 5.5 of http://cfd.direct/openfoam/user-guide/blockmesh/. However there multiple possible/valid definitions for one single block - depending on the vertex index to start with. This induces a local coordinate system for each block.
In your case the the blocks are defined in such a way that the first local coordinate direction of the first block matches the second local coordinate direction of the second block. That's why the discretization is specified differently.
You can either live with the different definitions of the discretizations, or change the one of the blocks (which might cause same problems with other adjacent blocks).
Hope that helps.
Cutter
cutter is offline   Reply With Quote
Definition of boundary conditions and initial velocity for fluid domain ddungntu CFX 0 March 24, 2019 23:58
[ICEM] Block meshing strategy for a radiused cylinder Polarbear ANSYS Meshing & Geometry 2 June 18, 2014 14:24
[General] Block Indices vanish??? macfly ParaView 3 April 26, 2014 13:53
[ICEM] Quest for seemingly simple Blocking (degenerate block) la7low ANSYS Meshing & Geometry 0 July 12, 2011 19:48
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 13:13
