[blockMesh] Cannot view arc edge in ParaView
Old   January 28, 2010, 14:47
Default Cannot view arc edge in ParaView
Erlend Grotle
erlendg is on a distinguished road
I have tried several blockMesDict files trying to make a cylinder using arc. blockMesh seems to go fine, but the arc is not visible in paraview (version 3.6.1). Anyone experienced this ? I used an example from the user manual so I recon the use of arc should be ok.
erlendg is offline   Reply With Quote
Old   November 13, 2015, 12:09
Ivan
iper88 is on a distinguished road
I had the same problem with paraview 4.1.0
It is at the moment just a 1 cell try.
BlockMesh code runs but it doesn't show any arc.
L 288;
D 88;
R 100;
B 722;
C 222;
alpha 35.0;
CapL 50;
Dd 50;
nzp -50;
zp 50;
//declaración de distancias
Fd #calc "10*$L";
Bd #calc "20*$L";
Ud #calc "8*$L";
Ax #calc "$Fd-$CapL";
Bx #calc "$Fd+$R-($R+$CapL)*cos(45.0)";
Cx #calc "$Fd+$R-$R*cos(45.0)";
//Dx #calc "$Fd+$R";
//Ex #calc "$Fd+$R+$B";
Cy #calc "$Dd+$R+$D";
Dy #calc "$Dd+$R+$D+($R+$CapL)*sin(45.0)";
//Gy #calc "$Dd+$L";
Hy #calc "$Dd+$D+$R+$R*sin(45.0)";
//Ly #calc "$Dd+$L+$CapL";
convertToMeters 0.001;
vertices
    ($Ax $Cy $nzp)
    ($Fd $Cy $nzp)
    ($Cx $Hy $nzp)
    ($Bx $Dy $nzp)
    ($Ax $Cy $zp)
    ($Fd $Cy $zp)
    ($Cx $Hy $zp)
    ($Bx $Dy $zp)
blocks
    hex (0 1 2 3 4 5 6 7) (1 1 1) simpleGrading (1 1 1) //0
edges
(   arc 1 2 (#calc "$Fd+($R-$R*cos(20.0))" #calc "$Cy+$R*sin(20.0)" $nzp)
boundary
mergePatchPairs
I don't understand why this occurs.
Moreover, after perform checkMesh got 1 failure:
  ***Number of edges not aligned with or perpendicular to non-empty directions: 6
  <<Writing 8 points on non-aligned edges to set nonAlignedEdges
Can anyone help? thanks in advance.
Last edited by wyldckat; November 13, 2015 at 14:46. Reason: Changed [QUOTE][/QUOTE] to [CODE][/CODE]
iper88 is offline   Reply With Quote
Old   November 13, 2015, 14:50
Retired Super Moderator
Bruno Santos
Quick answers:
  1. Arcs, splines and other complex edges are only meshed when there are enough discretization points. In other words, with only 2 points, the arc cannot exist:
    blocks
  2. The error message refers to the fact that no patch was defined here:
    boundary
    Therefore there is only one default patch, defined by default as of type "empty". Therefore, all 3 major directions are all empty and therefore there are no dimensions over which to solve the domain
My advice: start with a working mesh from a tutorial and gradually make changes and test what each change does to the mesh.
Old   November 14, 2015, 10:37
Ivan
Originally Posted by wyldckat View Post
Quick answers:
    blocks
    boundary
Thanks for your quick answer Bruno.
Your explanation has been very useful because I realized that just changing the number of cells per each direction (x' y'), arcs are drawn.
so I changed like this:
hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) //0
Thanks a lot.
Best regards
Ivan
Old   November 14, 2015, 10:44
Bruno Santos
Quick answer:
Originally Posted by iper88 View Post
hex (0 1 2 3 4 5 6 7) (1 1 1) simpleGrading (20 20 1) //0
That affects only the way the cells are distributed along their directions.
I hope you wanted to write this:
Because this defines that 20 cells are to be used along the first 2 main directions of the block, and only 1 cell along the 3rd direction.
Old   November 14, 2015, 11:22
Ivan
Quick answer:
Of course, just a mistake while writing the post. I've already corrected. Thanks!
[blockMesh] Openfoam: Meshing, where do my defaultFaces come from syntex OpenFOAM Meshing & Mesh Conversion 19 December 10, 2018 07:21
[blockMesh] meshing a cylinder Nico A. OpenFOAM Meshing & Mesh Conversion 6 June 19, 2017 14:12
Help -> Meshing of a Cylinder for Pouseuille Flow fisherman05 Mesh Generation & Pre-Processing 0 February 17, 2013 23:14
Multiblocks Rider OpenFOAM 16 April 12, 2012 03:00
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
