[mesh manipulation] mirrorMesh error
Like Tree1Likes
  • 1 Post By wyldckat
Old   December 2, 2015, 12:29
Default mirrorMesh error
WhiteW is on a distinguished road
Hello to everyone, I'm using OpenFoam 2.3.0. I'm facing a problem with the function mirrorMesh that should be simply to solve..
I have make a simple mesh of an half cylinder in Gambit and saved in msh format.
I would like to reconstruct the entire mesh in OpenFoam by mirroring it.
I initialy convert the mesh in the openfoam format using
fluent3DMeshToFoam half_cil.msh
And this creates the polymesh folder.
Then when I try tu run the command
mirrorMesh
But I get the followng error:
--> FOAM FATAL ERROR:
request for objectRegistry region0 from objectRegistry half_cil failed
available objects of type objectRegistry are
0()
From function objectRegistry::lookupObject<Type>(const word&) const
in file db/objectRegistry/objectRegistryTemplates.C at line 198.
FOAM aborting
What could be the cause of this error?
I have set the mirrorMeshDict file as follow:
| \\ / O peration | Version: 2.3.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object mirrorMeshDict;
planeType pointAndNormal;
pointAndNormalDict
basePoint (0 0 0);
normalVector (0 1 0);
planeTolerance 1e-5;
WhiteW is offline   Reply With Quote
Old   December 2, 2015, 15:28
Retired Super Moderator
Bruno Santos
Quick question: Can you please provide a small test case so that we can reproduce this error? Because there isn't enough information in your post to deduce what is the exact error
Or at least I don't remember a similar problem ever occurring with me and mirrorMesh.
Old   December 3, 2015, 08:46
Thanks for the reply.
I cleaned some files in the folder, and adjusted the boundary condition in the folder 0 and now it works.
I thought the mirrorMesh command wasn't related to the setting in 0 and system folder.
I have some question about the command:
- mirrorMesh mirrors a mesh on a given plane. It also merges the duplicated nodes on the mirror plane and removes the symmetry surfaces from the boundary list right? Other command are not necessary in order to "clean the mesh" right?
- in the case I'm studying (an airplane), one of the symmetry faces on the symmetry plane is not completely planar. Indeed some cells of this face are still present after the mirrorMesh command(as shown in the image). Is there a way to adjust this nodes (they y value has to be y=0)
Thanks!
Old   December 6, 2015, 11:07
Bruno Santos
Greetings WhiteW,
OpenFOAM is conceived to work as generically as possible. This means that for dynamic meshes, it can have the mesh in time folders for a particular time snapshot. In addition, the field fields in the "0" folder are sometimes taken into account by mesh utilities, for example for adding new boundaries or renaming old boundaries.
It should at least unassign all faces from the shared patch; in other words, the symmetry patch will have 0 faces assigned to it. Nonetheless, the shared patch might still be present in "constant/polyMesh/boundary" after mirrorMesh has done its job. You can use a nearly empty "system/createPatchDict" file and run createPatch for removing patches that have no faces assigned to them. A few tutorials in OpenFOAM demonstrate this (I'm using 3.0.0 as an example):
  • compressible/rhoPimpleDyMFoam/annularThermalMixer
  • incompressible/pimpleDyMFoam/oscillatingInletACMI2D
  • incompressible/simpleFoam/rotorDisk/
  • lagrangian/reactingParcelFilmFoam/rivuletPanel
  • lagrangian/reactingParcelFilmFoam/cylinder
  • multiphase/interDyMFoam/ras/mixerVesselAMI
You can either try using:
  • snappyHexMesh to snap these points onto a plane;
  • or use moveDynamicMesh, as demonstrated in the tutorial "mesh/moveDynamicMesh/SnakeRiverCanyon".
Best regards,
Bruno
kiski likes this.
Old   December 6, 2015, 13:18
Thanks wyldckat, it is all more clear now.
I'll study snappyHexMesh commands to modify the node position of the mesh.
Thanks again for your help!
WhiteW
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
