[blockMesh] Foam fatal error: neighbour cell face |
June 25, 2019, 16:05 |
#1 | ||
anu
Rep Power: 6 |
I am trying to simulate laminar flow over a delta wing in OpenFoam. I keep getting this error with blockMesh though, could someone help me out?
This is what my blockMeshDict looks like: I appreciate any help! |
June 26, 2019, 04:50 |
Rep Power: 15 |
It would seem that the face definitions for the "top" and "plate" patches have to follow a different order. For plate, change (4 3 5 4) to (3 4 5 3) and for top, change (1 2 0 1) to (0 1 2 0). As to why this is, it might be the case that when you have a wedge, OF is fine when the repeated vertex in the hex definition appears twice in a boundary patch definition. Hope this helps. Cheers, Antimony |
June 26, 2019, 11:53 |
anu
Rep Power: 6 |
Thank you so much! That worked perfectly.
blockmesh, blockmeshdict, deltawing, foam fatal error, openfoam |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
