[Other] Connect Mesh in OpenFOAM for turbine stage |
March 28, 2016, 00:02 |
Janry
Rep Power: 10 |
Hi Foamers,
Recently I've faced with a problem. We plan to simulate radial turbine stage with OpenFOAM. Now, I have draw two separate meshes, the rotor mesh and the stator mesh. The problem is that, how could I connect the two meshes together and form them into a whole turbine stage? After form them together, I'll use GGI to define the interface for simulating the rotor stage. Thanks and waiting for your reply. Janry |
March 28, 2016, 02:58 |
Peter
Rep Power: 11 |
Use the mergeMeshes utility.
March 28, 2016, 03:04 |
Janry
Rep Power: 10 |
Thanks Peter, Now the questions solved.
And i've found the utility of mergeMeshes is different for different versions of OpenFOAM. I've installed 2.3.0 and 3.0 extended on my PC, however, the 3.0 extended version seems more complexed when using it. |
March 28, 2016, 06:42 |
matej forman
Rep Power: 17 |
Yes you just run into a variety of differences between the extended project and foundation version. First, I would recommend to upgrade to version 3.0.1 from openfoam.org or v3.0+ from openfoam.com unless you know you want and must use version 2.3.0. Then yes, there are differences between the versions. One of them is, that mergeMesh from foundation or openfoam.com are generating AMI (arbitrary mesh interface) in between two nonconformal mashes, while the extended version creates GGI (general geometrical interface) which are two different implementation of the same behaviour. So before merging the meshes, it's good to know which openfoam you need to use for your simulation as the merged mesh will not work in the other fork of OpenFOAM.
Hope this helps |
March 28, 2016, 14:32 |
Niels Nielsen
Rep Power: 27 |
Linnemann PS. I do not do personal support, so please post in the forums. Last edited by wyldckat; January 1, 2018 at 14:45. Reason: updated link |
connect mesh |
[Salome] Problems for creating mesh in salome to OPENFOAM | bye bye my blue | OpenFOAM Meshing & Mesh Conversion | 8 | December 5, 2023 00:57 |
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM | nsf | OpenFOAM Meshing & Mesh Conversion | 86 | February 8, 2023 10:30 |
[Commercial meshers] About the Commercial and Closed Source Meshers discussed here | wyldckat | OpenFOAM Meshing & Mesh Conversion | 3 | July 22, 2020 22:09 |
[Salome] Mesh conversion Salome to OpenFOAM | VMartinez | OpenFOAM Meshing & Mesh Conversion | 11 | April 21, 2014 02:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
