[blockMesh] merge blocks
Old   May 13, 2016, 08:58
Default merge blocks
Alejandro
ancolli is on a distinguished road
Is there a way to merge blocks (consisting of several other blocks) with blockMesh? I have a cilinder (5 blocks) and I want to merge to a square (consiting of 3 blocks).
Thank u
ancolli is offline   Reply With Quote
Old   November 28, 2016, 12:54
cutter is on a distinguished road
please read http://www.cfd-online.com/Forums/ope...-get-help.html and provide a minimal example (blockMeshDict and especially a sketch of the expected result) that allows to reproduce the problem in order to maximize your chances to get useful help.
There's probably no functionality in blockMesh that merges meshes in the desired way. The mesher blockMesh creates block structured meshes. The mesh interfaces between neighboring blocks need to match. You therefore need to restructure your mesh and create a correct transition between the two parts.
Another alternative is the usage of AMI to connect two subdomains by interpolation (outside the scope of blockMesh).
Cutter
cutter is offline   Reply With Quote
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 03:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[blockMesh] How to merge blocks? Match, merge or stitch? gerritgroot OpenFOAM Meshing & Mesh Conversion 0 November 13, 2015 20:59
[ICEM] Two boxes connected by a cylinder, blocks merge where I don't want them to merge. Polarbear ANSYS Meshing & Geometry 4 April 30, 2014 15:21
