[CAD formats] Open stl with cat command
Old   December 10, 2015, 12:07
Default Open stl with cat command
Francesco
Zephiro88 is on a distinguished road
i have a little trouble. I need to generate a pipe to an internal simulation.
At first, i try to generate a rectangular pipe with Salome.
I create a box, then i explode all the face and finally i export all the face in stl file.
After that i rename the solid in all the stl and finally with
cat constant/triSurface/pipe/* > pipe.stl
i create my stl file with all region defined.
The procedure works fine with the box, but when i try to do the same things with the cylinder, the result of the
is an open file.
If i did not name the father stl (eg. the Inlet stl instead of strat with" solid Inlet" start with "solid") the resulting stl is closed and well defined, but without region defined.
Zephiro88 is offline   Reply With Quote
Old   December 11, 2015, 10:50
Francesco
If someone have also any advise to create a multi region stl or a multiregion obj with ProE or Salome, or any tutorial case guideline ecc... i would be grateful to follow the suggest.
At the end, i need only 3 region, Wall, Inlet and Outlet.
Old   March 29, 2016, 01:38
Florian Nguyen
Awak is on a distinguished road
Hello Francesco,
For what seems to be a rather simple geometry, I think that you can refer to the following tutorial: https://www.youtube.com/watch?v=1zQbU-E4k1U
I also faced the same problem with exporting faces of a solid as STL from Salome. This will occur every time you try to export circular shapes or curves, unfortunately. I noticed that Salome has very poor capability when it comes to exporting to faces to STL. However, if you mesh directly from Salome you will end up with a mesh that can be directly used in OpenFoam using ideasUnvToFoam.
Hope this solves your problem,
Florian
Awak is offline   Reply With Quote
Old   June 11, 2016, 05:44
Default stl not closed
Vignesh
vigneshTG is on a distinguished road
Hi Francesco,
Did you solve the problem ?? Can you tell me how to ?
I also used salome to make a simple geometry, exploded its faces, saved each surfaces as individual stl files and then manually combined them into one stl (as you did). When i do a surfaceCheck, i always get that my stl geometry is not closed.
I am able to successfully mesh it using cfmesh tool !! But checkMesh fails
***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
I have attached the case file in case some one wants to have a look.
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
