[blockMesh] 3D mesher using blockMesh
Old   June 21, 2016, 19:23
Default 3D mesher using blockMesh
Zhifang Hu
ce73stargazer is on a distinguished road
Hi there
I used blockMesh to create a simple cube, with 2 cells defined in all x,y,z direction, however, when I used checkMesh, it shows this is a 2D mesh. I am not sure why, any suggestion?
This is the output from checkMesh
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.1 |
| \\ / A nd | Web: http://www.extend-project.de |
| \\/ M anipulation | |
Build : 3.1-1dd681f6e943
Exec : checkMesh
Date : Jun 22 2016
Time : 09:13:05
Host : ubuntu14.04
PID : 5750
CtrlDict : /home/zhifang/foam/foam-extend-3.1/etc/controlDict
Case : /home/zhifang/OpenFoamTests/FoamExtendTests/damBreak
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
all points: 27
live points: 27
all faces: 36
live faces: 36
internal faces: 12
cells: 8
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 8
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Area [m^2] Surface topology
inlet 4 9 4 ok (non-closed singly connected)
bottom 4 9 4 ok (non-closed singly connected)
outlet 4 9 4 ok (non-closed singly connected)
atmosphere 4 9 4 ok (non-closed singly connected)
front 4 9 4 ok (non-closed singly connected)
back 4 9 4 ok (non-closed singly connected)
Checking geometry...
This is a 2-D mesh
Overall domain bounding box (0 0 0) (2 2 2)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 0)
Mesh (non-empty, non-wedge) dimensions 2
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (0 0 0) Threshold = 1e-06 OK.
Max cell openness = 0 OK.
Max aspect ratio = 1 OK.
Minumum face area = 1. Maximum face area = 1. Face area magnitudes OK.
Min volume = 1. Max volume = 1. Total volume = 8. Cell volumes OK.
Mesh non-orthogonality Max: 0 average: 0 Threshold = 70
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 2.5091e-15 OK.
Mesh OK.
End
And this is the blockMesh file
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
( 0 0 0 ) //0
( 2 0 0 ) //1
( 0 2 0 ) //2
( 2 2 0 ) //3
( 0 0 2 ) //0
( 2 0 2 ) //1
( 0 2 2 ) //2
( 2 2 2 ) //3
blocks
hex (0 1 3 2 4 5 7 6) ( 2 2 2 ) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 6 2)
wall bottom
(0 1 5 4)
patch outlet
(1 5 7 3)
patch atmosphere
(2 3 7 6)
empty front
(4 5 7 6)
empty back
(0 1 3 2)
mergePatchPairs
ce73stargazer is offline   Reply With Quote
Old   June 21, 2016, 20:51
Antimony is on a distinguished road
Your front and back patches have been defined as being of type empty.
As a result, OF considers it to be a 2D mesh...
Cheers,
Antimony
Antimony is offline   Reply With Quote
[OpenFOAM.org] blockMesh issue on openfoam6 startup - ubuntu 16.04 bjdarrer OpenFOAM Installation 7 August 25, 2020 19:15
[snappyHexMesh] Cylindrical blockmesh to Improve snappyHexMesh Results nicholas.jones OpenFOAM Meshing & Mesh Conversion 3 May 16, 2019 09:52
[ANSYS Meshing] ANSYS Mesher cann't update geometry from parameter set M.Shousha ANSYS Meshing & Geometry 4 November 25, 2016 05:11
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 08:37
