[blockMesh] snappy with multiple blocks
Old   June 29, 2016, 15:14
Default snappy with multiple blocks
Almond Wong
BakedAlmonds is on a distinguished road
I have created multiple blocks within blockMesh and a view of "paraFoam -block" is attached. I did this so that domain nearer to the terrain can have a finer mesh defined in blockmesh
However, when i applied snappy, only one of the block remains which is the one with cordinated specified by locationInMesh.
How can i keep all the blocks created by blockmesh?
BakedAlmonds is offline   Reply With Quote
Old   June 29, 2016, 23:02
Antimony is on a distinguished road
You will need to merge the blocks into a single block if you want snappy to see all the blocks. Otherwise, to snappy, depending on where your locationInMesh point is, it will not see the other blocks and consequently remove the mesh from that location (you can see the difference in cell count after the "removing unreachable regions of mesh" in the log of snappy)
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   June 30, 2016, 03:54
Almond Wong
Thanks for the reply Antimony!!
Can I check with you on how to merge the block? Do i create new patches for the overlapping faces and merge them using mergePatchPairs?
Or could you guide me thru an example on how to merge the blocks?
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 03:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[snappyHexMesh] Meshing multiple blocks Hanno OpenFOAM Meshing & Mesh Conversion 3 February 17, 2011 12:14
