[Other] Using Smoothed Particle hydrodynamics
Old   July 5, 2016, 02:28
Default Using Smoothed Particle hydrodynamics
abhishek chawan
abhishek chawan is on a distinguished road
Hi all, i have a question in using SPH for my solid glass particle impact on Al Plate? the question is
case 1 - I have a solid spherical glass particle of size 0.5 mm and i give a particle size of 0.015, with this i generate around 3489 particles, my question follows in case 2
case 2 - Now imagine i have the same spherical glass particle but with a void ratio of around 0.6, so does it mean i reduce the number of SPH particles by 60 % ? and is this method valid ??? If not then please help me what is the right method to model a particle with high void ratio in the range of 0.6 - 0.7.
Regards
Abhishek Chawan
abhishek chawan is offline   Reply With Quote
Using Smoothed Particle hydrodynamics in ANSYS abhishek chawan Mesh Generation & Pre-Processing 0 July 5, 2016 02:31
[ANSYS Meshing] Using Smoothed Particle hydrodynamics abhishek chawan ANSYS Meshing & Geometry 0 July 5, 2016 02:29
Using Smoothed Particle hydrodynamics abhishek chawan Structural Mechanics 0 July 5, 2016 02:25
Basic and simple SPH-code questions (smoothed particle hydrodynamics) Peacekeeper Main CFD Forum 2 March 12, 2014 16:29
injection problem Mark New FLUENT 0 August 4, 2013 01:30
