[Other] Meshing question for a conjugate heat transfer problem
Old   July 5, 2016, 22:21
Lightbulb Meshing question for a conjugate heat transfer problem
anonymous
stingph is on a distinguished road
Dear FOAMers
I am conducting a simulation of conjugate heat transfer (CHT) problem in which the fluid flows in a heated circular tube. The solver ChtMultiRegionSimpleFoam is used. I am planning to add uniform volumetric heat source inside the solid domain (tube wall) using the fvOptions utility. At the solid-fluid interface the compressible::turbulentTemperature CoupledBaffleMixed is used. In the fluid domain, the mesh is refined at the solid-fluid interface since the flow is turbulent and I want the boundary layer to be solved using Low-Re turbulence models.
My doubts are:
1 Whether the mesh in the solid domain needs to be refined in the radial direction as well or a uniform spaced mesh is OK?
2 If a nonuniform mesh in the solid domain has to be used, does it have to be adjusted under different heat source conditions?
Thank you!
stingph is offline   Reply With Quote
conjugate heat transfer, mesh
Conjugate Heat Transfer Analysis Problem redwanamit034 FLUENT 1 June 16, 2015 23:39
Issues with creating "regions" for conjugate heat transfer problem!! vabishek OpenFOAM Pre-Processing 6 April 23, 2015 16:23
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 15:41
conjugate heat transfer problem Andreas FLUENT 2 February 6, 2002 03:15
