July 21, 2011, 10:27 |
searchableBox at an angle?
Alex
Rep Power: 15 |
Is it possible to define a type searchableBox with an angle?
I want to specify a region for a rectangular area that is not parallel to the yz plane. Thank you |
October 17, 2017, 03:05 |
Bump
Fridrik Magnusson
Rep Power: 8 |
Did you find a solution back in 2011, Want the same thing.
- Fridrik Magnusson |
November 1, 2017, 22:47 |
November 2, 2017, 01:59 |
Fridrik Magnusson
Rep Power: 8 |
Nope :/ i found a workaround, drew it in a CAD program, where it should be, then exported it as an *.stl - Then it had it shape and rotation.
November 2, 2017, 02:39 |
#5 | |
I saw your another post about editing snappyHexMeshDict with coordinateRotation. I am trying to figure out a solution in this direction. Any suggestion from your experience? |
Dynamic contact angle calculation in multiphaseInterFoam | rajeshchem | OpenFOAM | 3 | December 23, 2022 14:00 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 02:39 |
[snappyHexMesh] snappyhexmesh refine volume with angle using something similar to searchableBox | jptorol | OpenFOAM Meshing & Mesh Conversion | 0 | May 13, 2015 16:57 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 17:24 |
