February 2, 2017, 23:14 |
Grading in gmsh
Declan
Rep Power: 9 |
I am trying to grade cells approaching a line (the bottom of my domain) and am wondering if there is a way to do this similar to blockMesh's simpleGrading tool. See the image below for what I have (left) and what I would like to have (right). I know you can specify the grid size on individual points in gmsh but can't find anything in the documentation about specifying it over a line. |
February 3, 2017, 02:54 |
#2 | |
Mikko
Rep Power: 12 |
This is only possible for structured mesh (transfinite line). You can give a geometric ratio either for one end (Using Progression) or for both ends (Using Bump).
See more in the documentation: Structured grids Quote:
February 3, 2017, 13:35 |
Declan
Rep Power: 9 |
Thanks Mikko, I had missed that in the documentation.
[Gmsh] Converting gmsh to OpenFoam | Friendly | OpenFOAM Meshing & Mesh Conversion | 3 | June 26, 2018 05:46 |
[Gmsh] Insatlling gmsh from the source code-issue? | CFD-Lover | OpenFOAM Meshing & Mesh Conversion | 20 | June 12, 2018 06:39 |
[Gmsh] Cgns support for gmsh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 1 | July 13, 2016 11:27 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
