[Gmsh] problem in transfiniting the volume in gmsh
Old   March 30, 2017, 08:41
Default problem in transfiniting the volume in gmsh
Bharadwaj Bhushan
Bharath Bhushan is on a distinguished road
hello guys,
I want to do 3D mesh on imported nozzle geometry in gmsh. I can't modify anything regarding the geometry nor can insert anything like points or lines or planes. All I can do is transfinite and recombine it. But when I transfinite and recombine the surface and when I do 3D mesh, surface mesh looks good but inside the volume it scrambles out. So to get the ordered mesh, I need to transfinite the volume. But to transfinite the volume it needs 5 to 6 faces or or number of points or something like that, but I cant create any planes, so unable to do transfinite volume. Only
please anybody has some ideas about this
thank you
Bharath Bhushan is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 10:44
multiphase turbulance case floating error harsha_kulkarni OpenFOAM Running, Solving & CFD 3 February 18, 2016 05:06
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
