[snappyHexMesh] Retaining mesh inside and outside of the region occupied by .stl file
Old   April 13, 2017, 16:43
Default Retaining mesh inside and outside of the region occupied by .stl file
Pavan
pvpnrao is on a distinguished road
I have the .stl file of a closed geometry (a simple cylinder) which I superimposed on a Cartesian hex mesh (a bigger cube) and ran snappyHexMesh. Everything works fine.
However, snappyhexmesh deletes the mesh from the region lying inside .stl file geometry.
Is there some option in snappyhexmeshdict that I can switch-off to avoid it from deleting that mesh?
I need to retain mesh on both inside and outside of the .stl surface
pvpnrao is offline   Reply With Quote
Old   April 17, 2017, 02:27
Antimony is on a distinguished road
You would need to specify and set cellZoneInside to inside, among others.
See page 31 for more details: https://openfoamwiki.net/images/f/f0...SlidesOFW7.pdf
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   April 25, 2017, 06:22
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
Do you want different cellzone to cylinder? Are you planning to solve it as solid?
For quite similar problem, my code was something like this:
Surface1
level (2 2);
faceType baffle;
cellZone fluid1;
cellZoneInside solid1;
locationsInMesh
((-5.0, 0.0, 0.0) fluid1)
((-1.0, 0.0, 0.0) solid1)
KaLium is offline   Reply With Quote
Old   April 28, 2017, 19:13
Pavan
Antimony ... KaLium
Thank you very much for your responses.
KaLium: Yes, I want to model the internal mesh as solid. I will try your suggestion.
If is it not too much to ask. I am also struggling to reference the solid cellzone in the solver. How do you realize a solid within the fluid region in the solver, I believe this is done my adding a forcing term in on the right hand side using fvOptions which will only work for on solid cellzone...but I have not been successful in getting it to work ...
can you please give me some insights on how to get it working
Do you have any sample code ?
how is the solid-liquid interface treated in openfoam
Thanks in advance
